I need a Cheap and Cheerful DAC asap
0 Members and 1 Guest are viewing this topic. Read 5110 times.
siava1018
« on: 26 Sep 2011, 03:00 pm »
So i finally ordered a new amp(hifimediy T1) and a Dodd buffer. Now i need a real dac to replace my uca 202.
It needs to have USB or optical and run on 12 or 24vdc.  Id like to spend under $200 the cheaper the better.
Tubo
Re: I need a Cheap and Cheerful DAC asap
« Reply #2 on: 26 Sep 2011, 03:34 pm »
srb
« Reply #3 on: 26 Sep 2011, 03:41 pm »
Fiio-D3
Also consider the Fiio-D5 which has USB input but does not do 192K, only 96K
The Fiio D5 runs on USB bus power, however the Fiio D3 requires a 5VDC supply so some type of voltage regulator or other circuitry will need to be incorporated.
HAL
« Reply #4 on: 26 Sep 2011, 04:35 pm »
A Musiland Monitor 01US is $90 on Ebay.  They are USB powered and asynchronous. They support up to 24/192KHz.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #5 on: 26 Sep 2011, 10:53 pm »
Good deal. Is a must have for that price.
Go for it!
siava1018
« Reply #6 on: 26 Sep 2011, 11:19 pm »
do i need to use the drivers for the musiland? I have OSX
JohnR
« Reply #7 on: 26 Sep 2011, 11:31 pm »
I believe the musiland is windows-only. Also, it's not a DAC.
siava1018
« Reply #8 on: 26 Sep 2011, 11:35 pm »
If its not a dac then what is it?
JohnR
« Reply #9 on: 26 Sep 2011, 11:49 pm »
My mistake - the 01 US is a DAC, the 01 USD is a USB-SPDIF convertor.
jtwrace
    • TIPP YouTube Channel
« Reply #10 on: 27 Sep 2011, 12:01 am »
Wonder how good they sound.  HAL?
siava1018
« Reply #11 on: 27 Sep 2011, 12:04 am »
Does anyone have any experience with the Filo D3?  Im thinking about getting it just for now and save up for a better dac.
HAL
« Reply #12 on: 27 Sep 2011, 01:19 am »
Jason,
The Monitor 01US sounds very good indeed.   :thumb:
Not sure about MAC OSX, I am a Windows guy.  Works fine with Win 7 and their driver.
I.Greyhound Fan
« Reply #13 on: 27 Sep 2011, 05:18 am »
I would take the MCM DAC over the Fiio just based on the reviews of the Beresford TC-7510 DAC.  The MCM is an exact copy with the same components.  I think that you will get more milage out of it.
TONEPUB
« Reply #14 on: 27 Sep 2011, 05:32 am »
Ive got an original Music Streamer +...
Only does 16/44, but it's yours for $100 if you want it.  Brand new in box.  That will include shipping and PayPal fees.
PM if interested...
I.Greyhound Fan
« Reply #15 on: 28 Sep 2011, 12:16 am »
Here are some other DAC's to consider-
http://www.hllyhifi.com/dac-c-1.html
groovybassist
« Reply #16 on: 28 Sep 2011, 12:24 am »
I've got a very gently used Music Streamer II+ I'd be willing to part with for $200. Just bought the EE Minimax DAC Plus.
Mike
Gopher
« Reply #17 on: 28 Sep 2011, 01:17 am »
A buddy offered to sell me an UltraFi iRoc for $200 today.  I think that would be outstanding in your price range.  Drop me a PM if you want his email.
