My new Cheap and Cheerful system
0 Members and 1 Guest are viewing this topic. Read 3191 times.
siava1018
« on: 25 Sep 2011, 04:13 pm »
Dodd inline buffer>Hifimediy T1 sta519a on batteries>X-LS Encores
Im still deciding on my dac, I have a dac AH right now but after the battery mod it has minimal vol output so ive been using my behringer uca 202 but id like something better.
siava1018
Re: My new Cheap and Cheerful system
« Reply #1 on: 1 Oct 2011, 03:13 am »
Amp came today and the buffer, 24v charger, batteries and dac are on their way.  I got a beresford 7520 dac from a AC member and all thats left is to call danny for the speakers, norez and flat pack and hit up rat shack for some small items.
eclein
« Reply #2 on: 1 Oct 2011, 03:30 am »
Congrats!!! You got a good start...what speakers are you getting?? I had the NX2 here for awhile and they are an excellent choice, they sound even better with a sub. Enjoy!!! :thumb:
siava1018
« Reply #3 on: 1 Oct 2011, 07:19 am »
Im buying the xls encore
Poultrygeist
« Reply #4 on: 5 Oct 2011, 09:03 pm »
pictures?
eclein
« Reply #5 on: 5 Oct 2011, 09:11 pm »
Sounds good!!! Let us know how it sounds when you get it all together!!! :thumb:
siava1018
« Reply #6 on: 3 Nov 2011, 01:07 am »
I have the 3.3 caps from the buffer hooked up to the inputs on the amp, can i remove the big blue caps on the amp?
2wo
« Reply #7 on: 9 Nov 2011, 10:30 pm »
Yes you can, or you can solder a jumper on the bottom and leave them in place...John
siava1018
« Reply #8 on: 13 Nov 2011, 12:03 am »
thanks i just removed them and used some leftover wire from the buffer to connect the pads. Speaker kit will be here wed. so il start building the boxes tomorrow.
