Hifimediy DAC
0 Members and 1 Guest are viewing this topic. Read 7637 times.
siava1018
Hifimediy DAC
« on: 24 Sep 2011, 10:38 pm »
http://hifimediy.com/?wpsc-product=hifimediy-uac27-mini-usb-dac-pcm2706wm8501-usbspdif-converter
Has anyone tried this? I assume its better than the beheringer uca-202 im using now.
HT cOz
Re: Hifimediy DAC
« Reply #1 on: 24 Sep 2011, 11:39 pm »
They have another DAC coming soon that is even more interesting.
siava1018
Re: Hifimediy DAC
« Reply #2 on: 24 Sep 2011, 11:40 pm »
where can i get some info on that?
HT cOz
wushuliu
Re: Hifimediy DAC
« Reply #4 on: 2 Nov 2011, 04:30 pm »
FYI, the new ones are now available. You can add whatever kind of output you want. Two edcor transformers on the output and you've got a great dac.
http://hifimediy.com/?page_id=18&category=7
JohnR
Re: Hifimediy DAC
« Reply #5 on: 25 Apr 2012, 07:18 am »
I was just looking at that today and was about to post... then I remembered "search before posting"... :lol:
Which Edcors are you referring to? These have a spec of 100Hz - 15k, although that is probably at max input voltage.
I've wondered about these differential-output DACs. The datasheets say (the one I looked at anyway) that you do need to treat them as a differential signal, so you have various DACs including DacMagic and miniDSP 2x8 that buffer the differential outputs to get the differential/"balanced" out, then another op-amp to get the single-ended output. On the DM I've read that taking one leg of the balanced out sounds better than the single ended out, altho I never tried it when I had one, nor have I tried it with the miniDSP.
wushuliu
Re: Hifimediy DAC
« Reply #6 on: 25 Apr 2012, 09:16 am »
I believe these are the ones that are often used:
http://www.edcorusa.com/p/156/xsm600-600
Some folks use much higher (10k) impedance as well.
JohnR
Re: Hifimediy DAC
« Reply #7 on: 25 Apr 2012, 09:28 am »
Great! Not much to complain about here.
JohnR
Re: Hifimediy DAC
« Reply #8 on: 5 Jul 2012, 04:04 pm »
I seems there's a redesign in the works on this one. I'm not really sure why - a MCU?? Surely there must be a ready market for a DAC that's just what it says - minimal extra stuff.
wushuliu
Re: Hifimediy DAC
« Reply #9 on: 6 Jul 2012, 04:59 am »
Yes, strange. Price keeps getting higher, too.
JohnR
wushuliu
Re: Hifimediy DAC
« Reply #11 on: 4 Aug 2012, 06:15 am »
JohnR
Re: Hifimediy DAC
« Reply #12 on: 6 Aug 2012, 09:31 am »
Hm hm hm.
wushuliu
Re: Hifimediy DAC
« Reply #13 on: 14 Aug 2012, 08:18 am »
Got it a few days ago. Very fast shipping. Will be a little while before I assemble it though...
HT cOz
Re: Hifimediy DAC
« Reply #14 on: 16 Aug 2012, 12:49 am »
I'm looking forward to your thoughts Wushuliu.
wushuliu
Re: Hifimediy DAC
« Reply #15 on: 16 Aug 2012, 08:05 am »
Actually I am selling the board and transformer. It was a rash decision to buy. I had forgotten that
one of my goals was to build the Salas shunt regulated supply for a dac and the hifimediy would not work for this. So I am gong to build a 5v version and power the odac. I did not pay close enough attention to the hifimediy thread. Too many projects to keep track of lately.
