FS Carver A760X Amplifier
0 Members and 1 Guest are viewing this topic. Read 2552 times.
Jfondell
« on: 22 Sep 2011, 11:26 am »
I have a like new Carver A760X Amplifier back from Rita's. This was signed by BOB Carver and was totally restored. I purchased this to power my new Tyler Acoustics D1's. I used this amplifier for maybe 10 hours but then my Krell came in and I never hooked this back up. I am asking 800.00 plus shipping and PP 3% OBO. Please respond to [email protected] or contact here. Pictures will be sent to prospective buyers upon request.
James Fondell
A-760x FEATURES
Certified by Lucasfilm, Ltd. for use in home THX audio systems Magnified Current technology for increasing voltage and current capability Total Direct Coupling for high damping factor at all frequencies
Each channel protected by: individual fusing, excess temperature sense, DC fault sense, power-on delay, shorted load sense.
Minimal signal path design, with on card I/O connectors eliminating internal interconnect cables
Gold Plated RCA Jack Connections Dual analog lighted meters with range selection switch
Meter light On/Off switch
Individual calibrated level trim controls for each channel
Removable handles for 17" cabinet space (with trim caps)
Designed and built by Carver Corporation in Lynnwood, WA USA
A-760x SPECIFICATIONS
Frequency Repsonse: 20-20kHz +0,-0.2dB
Power Output: FTC 20hz-20khz 8ohm 380 watts per channel
4ohm 600 watts per channel 2ohm 1150 watts per channel
Bridged mono power output: 1200 watts into 8 ohms
THD: less than 0.08%
Dynamic Headroom: >1.0dB @ 8ohms both channels driven
Gain: 29.0 dB (+/- 0.5dB)
Input Impedance 47 kohms
Damping Factor: >150 typical (20hz-20 khz)
