0 Members and 1 Guest are viewing this topic. Read 1836 times.
I use Pure Music and go straight into my digital crossover. However to the OP, the 16-bit DAC is the limiting factor, there is no way to add extra information (that won't get lost at the DAC anyway).
Thanks John. I wasn't certain if the Touch would ramp it up to 24 bits for the volume control and only pass the 16 bits for audio with a 16 bit DAC or not. Of course, attempting to use a USB DAC with the Touch may be a bit of an issue anyway. I have read that you can modfiy scripts in Linux to allow it to do this, I wonder what the sonic penalty is when going this route?Best,Ed
Volume control is multiplying the original bits e.g. by .5 to half the volumeAs a consequence you lose resolution.Because of the quantisation error dither should be applied in case of 16 bits.With a 24 bit DAC the quantisation error is at -144 dBFS down so probably way below the noise floor of your gear.However moderate digital volume control won’t do much harm.A discussion on this subject can be found here: http://www.whatsbestforum.com/showthread.php?3813-Digital-Volume-control
