0 Members and 1 Guest are viewing this topic. Read 15732 times.
Then from the outside it would seem that ss amp is superior to a given tube amp. Same rough capability, no tubes to replace, no heat.
Since the '70's FTC guidelines stipulate that the output rating is determined with a full bandwidth signal (20-20k i.e.; pink noise), can you site who specifies output power at 1kHz only? Anyone who does that is technically guilty of false advertising according to the FTC.Don't confuse John Atkinson's tests (which are done with a 1kHz signal) with how the product is specified. In fact, many solid state amps will measure better and be capable of higher power into higher frequencies than tube amps (those pesky tranformers).
My krell sounds better when its warm! Thanks Rim, I was wondering why.
There was nothing wrong with my amplifiers, they were bench tested and fully working. Yes, I'm aware that tube amplifiers are bandwidth limited, i.e. transformers. My "premise" is not flawed, because it didn't originate with me. It was a lesson taught to me by a very capable engineer with real credentials. He designed many amplifiers in his lifetime both tube and solid state. Some of his work ended up in the Space Shuttle program, The Indiana Jones ride at Disneyland and several of his ultra precision (tubed) calibration amplifiers are STILL in use at the NIST/Bureau of Standards. He was teaching me some of the differences between solid state and tubes. It certainly depends on the specific amplifier, but tubes do have the advantage. More Joules available because of the substantially higher power supply voltages. Your typical solid state amplifier CANNOT deliver full output at full bandwidth all the time. Amongst other places that I've worked in electronics, I spent some time at THRESHOLD final testing their amps before they went out the door, using an Audio Precision System. So I am experienced testing amplifiers both the old fashioned way and the more modern automated way.There are certainly several kick a** solid state amps out there, but lets take an ordinary consumer 7.1 (multi channel) home theater receiver and put it to the test. Ha! FTC be damned. FTC rules are only there for truth in advertising, so manufacturers cannot inflate or make exaggerated claims. But whatever you believe is OK by me, not worth arguing with you especially since you already have your mind made up. Being a big shot salesman and all that. Most salesman know how to really hype it up, but beyond that hey usually don't know the difference between a P and N channel device, don't know their Cathode from an Anode.
I believe you. I like the 1950's vintage florescent lamp. They sure made things to last back then. New ballasts go out all the time.
Having modded lots of tube electronics, and designed some of my own, I can tell you that its not usually the frequency response that usually makes for a smooth or warm sound. Its the compression at HF. This is not a characteristic of tubes, but can be if the power delivery is not optimized for HF.
Very interesting, I'd like to learn some more about this.
There was nothing wrong with my amplifiers, they were bench tested and fully working. Yes, I'm aware that tube amplifiers are bandwidth limited, i.e. transformers. My "premise" is not flawed, because it didn't originate with me. It was a lesson taught to me by a very capable engineer with real credentials. He designed many amplifiers in his lifetime both tube and solid state. Some of his work ended up in the Space Shuttle program, The Indiana Jones ride at Disneyland and several of his ultra precision (tubed) calibration amplifiers are STILL in use at the NIST/Bureau of Standards. He was teaching me some of the differences between solid state and tubes. It certainly depends on the specific amplifier, but tubes do have the advantage. More Joules available because of the substantially higher power supply voltages. Your typical solid state amplifier CANNOT deliver full output at full bandwidth all the time. Amongst other places that I've worked in electronics, I spent some time at THRESHOLD final testing their amps before they went out the door, using an Audio Precision System. So I am experienced testing amplifiers both the old fashioned way and the more modern automated way.There are certainly several kick a** solid state amps out there, but lets take an ordinary consumer 7.1 (multi channel) home theater receiver and put it to the test. Ha! FTC be damned. FTC rules are only there for truth in advertising, so manufacturers cannot inflate or make exaggerated claims. But whatever you believe is OK by me, not worth arguing with you especially since you already have your mind made up, being a high end salesman and all that. Most salesman really know how to hype it up, but beyond that they usually don't know the difference between a P and N channel device, don't know their Anode from an Cathode.
Back then it was "American" made, now it's all made in China. I try and buy American whenever I can. Mostly though, I avoid stuff that's been made in China, not because I'm anti Chinese, but because most Chinese goods are crap. Unfortunately it's getting harder and harder to find anything that isn't made in China. Anyway, I always check for country of origin before making a purchase.
Well, your assertions may have been true some years ago, but do not think this is true today. The Chinese now make some pretty impressive audio equipment, and they seem to be the only ones who can make a current KT88 that lasts more than a couple hundred hours without shorting out.Check out components from companies such as Eastern Electric, and you will see a high quality, well made product that holds it own against anything made at or slightly above it's price point. Quality control comes and goes in cycles. Years ago, Japanese made items were considered low rent. By the 90's, Japan was equated with quality. Look at Korean cars, and one sees the same cycle.
Be advised I removed one of the postings by AE in this thread. Please keep the discourse civil. Also, this is not a forum to debate ss vs tubes.
