BDA-1 Firmware Update
0 Members and 1 Guest are viewing this topic. Read 3941 times.
larevoj
« on: 18 Sep 2011, 02:42 pm »
Hi James,
I have got the BDA-1 for awhile now and noticed there is a RS232 port for firmware update as mentioned in the manual below...any update on the way?? Thanks...
FIRMWARE UPDATES
BDA-1 firmware updates will periodically be available from Bryston dealers or from Bryston Ltd. directly. These firmware updates will be supplied as an executable file (program) which, when executed on your PC, will search for available serial ports on your computer and then search for the BDA-1 before upload- ing and automatically installing the new firmware in your BDA-1.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-1 Firmware Update
« Reply #1 on: 18 Sep 2011, 02:44 pm »
Hi larevoj
There have not been any DAC software updates since SN 25.
James
adol290
« Reply #2 on: 18 Sep 2011, 04:30 pm »
Hi larevoj
James
James I have SN 15.
You told me there were no updates.
So are there updates for mine?
« Reply #3 on: 18 Sep 2011, 04:46 pm »
James I have SN 15.
The update at 26 was just a small change in the remote code so it did not affect performance at all.
James
larevoj
« Reply #4 on: 19 Sep 2011, 01:41 am »
Hi larevoj
James
Thanks James...  :)
yo2tup
« Reply #5 on: 19 Sep 2011, 05:36 am »
how do you know what version is currently on the BDA-1?
« Reply #6 on: 19 Sep 2011, 11:14 am »
Hi - we keep track through the serial numbers but other than a few tweeks for remote control there have not been any changes.
james
