0 Members and 1 Guest are viewing this topic. Read 10421 times.
What does the info above tell me?
<<Calculations for a New Lamp>>150" Screen (Lamp Low Best Mode)= 5.6fL150" Screen (Lamp HIGH Best Mode)= 7.1fL150" Screen (Semi-Accurate NON-Best Mode)= 14.5fL150" Screen (Absolute Brightest Mode)= 20.1fLThe above is for my set-up: Epson 8350 w/a 150" screenWhat does the info above tell me?
So far its quite good. Football games are no problem, and even hockey games are fine. It is something else to always be able to find the puck, or see the golf ball in flight, when watching sports on the big screen. Can't do that on a plasma.Since this is my 1st projector, take it with a grain of salt of course.If the latest $1200 Mitsu was brighter & able to be purchased locally, i'd have DLP now. The 8350 was a compromise & convenience, but i don't regret it one bit. My other tv is a good samsung 42" plasma & is smoother & more 3-D in some ways (with a satellite signal)...but there's no turning back! Its absolutely true that standard tv's seem really small now. What I took from pre-purchase research was that in the last 2 years the low cost pj's have been excellent in terms of performance. We've also benefitted from the jump to 1080p as well, which is obvious when lower resolution commercials come on the screen (or with Netflix). I'm thrilled to have not spent $5K or much more to get this kind of picture. Best Buy gave me 36 months no interest pmt credit card as well I spent about $2K overall, same as a decent 65" plasma. no contest
Having a 2yr warranty on the bulb is comforting...no clue how fragile they are but assume i will find out.
The entire process certainly is a learning experience. Wisdom & feedback are appreciated.Wish I had deep pockets to not have to worry about using a budget pj, but so far no buyers remorse.I run it on Normal lamp mode, at 500 hrs now. Everything seems the same, but I hear you. Having a 2yr warranty on the bulb is comforting...no clue how fragile they are but assume i will find out. I was lucky to have a professional installer in the local audio club too, avhandyman has sweated many hours to get my rig up & running. He visited my place when the pj was table mounted & beaming at a painted wall. After measuring & observing he selected the size, gain, mfgr, color, etc of the screen. In a few yrs i'll upgrade to a house & man cave, then get serious into video. projectors get freakishly expensive for the good stuff.
