Need good inexpensive digital cable recommendations
0 Members and 1 Guest are viewing this topic. Read 1871 times.
pugs
« on: 21 Apr 2004, 02:47 pm »
I need a 9ft digital coax and short (1/2 to 1m) digital optical cable. I really don't want to spend that much, but also don't want to sacrifice too much quality either.
The 9ft coax would connect my Pioneer dv47a to my cary 303/200 CDP. I don't know if I'll use the Pioneer much as a transport, but it would be a nice option to have.
The digital optic able would connect the Pioneer 47a to my Denon 4800 receiver for my movie sound. Right now I'm using a Better Cables Silver Serpent digital coax. I want a cheap digital optic to replace it, but don't want to sacrifice sound quality.
I think I'll go with Blue Jeans cable for the coax. It seems that people are happy with it and it only costs around $17. Any recommendations for a digital optical? Under $20 would be nice, but that's flexible.  Any other cheap coax ideas?
Marbles
« Reply #1 on: 21 Apr 2004, 02:56 pm »
The Better cables OPTICAL is very good...it is GLASS, not plastic and I like mine just fine.  It is also very reasonably priced.
pugs
« Reply #2 on: 21 Apr 2004, 03:29 pm »
I see Heartland cables offers Eichman Bullets for the digital coax.  Are they worth an extra $10 over the Canare RCAP?
Marbles
« Reply #3 on: 21 Apr 2004, 03:33 pm »
I would get the Bullets for $10 more, but then again I went up to the Silver WBT's @$50 each.
Connectors make a difference based on a recent experiment I did with Bolder digital cables using Canare, Eichman Silver, WBT Nextgen copper, and WBT Nextgen silver connectors
kana813
« Reply #4 on: 21 Apr 2004, 11:54 pm »
The Audience Conductor SPDIF is an excellent cable for the money.
I use a 5M AES run in my system and it works great.
tinear99
« Reply #5 on: 22 Apr 2004, 02:01 am »
I like the Heartland with the bullets also, an excellent cable reasonably priced that uses great parts. Check out the Sterovox HDVX also.
pugs
« Reply #6 on: 22 Apr 2004, 04:40 am »
I just noticed that the Heartland cables use Canare L-5CFB.  I was thinking it was Belden 1694 for some reason.  Does anyone have an opinion on the Canare vs. Belden cables?
