dBpoweramp question
0 Members and 1 Guest are viewing this topic. Read 2679 times.
headshrinker2
dBpoweramp question
« on: 17 Sep 2011, 08:59 pm »
Greetings everyone,
Planning on downloading and using dBpoweramp to burn a bunch of my CD's to FLAC files before my BDP-1 comes on Monday :)
On the companies website, I see three different versions of the program:
(1) dBpoweramp FREE
(2) Power Pack and mp3 License, and
(3) dBpoweramp Reference
Would the free version be sufficient for ripping and converting existing Apple Lossless to FLAC?  Or do should I consider one of the paid versions?  I can't find on the website where it allows me to download the free version?  I'm sure I'm missing something obvious.
Thanks.
saveloy
Re: dBpoweramp question
« Reply #1 on: 17 Sep 2011, 09:28 pm »
I have the full Reference version.  I believe you will need this version, also.
Kyri
RLL1
« Reply #2 on: 17 Sep 2011, 09:52 pm »
Greetings everyone,
(1) dBpoweramp FREE
Thanks.
I have the Reference version as well.
Rick
Alpha10
« Reply #3 on: 18 Sep 2011, 08:14 am »
I would say to just buy the; dBpoweramp Reference version. I did as others have said, you will not regret it, one of the easiest to use and useful programmes you will ever purchase..
Cheers
headshrinker2
« Reply #4 on: 18 Sep 2011, 01:48 pm »
Thanks everyone.  I did go ahead and purchase the Reference version.  I am busy securely ripping!
ted_b
« Reply #5 on: 18 Sep 2011, 02:08 pm »
And for me the Reference version brings the most wonderful batch processor (DBPoweramp Batch Converter), so any conversions required can be done in a large batch, and you can direct it to create separate folders, subfolders, etc..
headshrinker2
« Reply #6 on: 18 Sep 2011, 05:41 pm »
I'm looking forward to trying with it with some Apple Lossless files I want to convert to FLAC.
Deftone
« Reply #7 on: 28 Sep 2011, 05:49 pm »
Out of curiosity regarding the dbpoweramp.Do you use the default naming scheme or do you create your own naming and do you leave the rip at default 5.
headshrinker2
« Reply #8 on: 28 Sep 2011, 09:11 pm »
I'm new to the program, but I have been using the default naming scheme and compression level (i.e. 5).
terrycym
« Reply #9 on: 29 Sep 2011, 06:23 am »
No compression can make a difference
