hidden files on HDD on BDP-1
0 Members and 1 Guest are viewing this topic. Read 10602 times.
terrycym
Re: hidden files on HDD on BDP-1
« Reply #20 on: 20 Sep 2011, 06:13 pm »
The BDP-1 Front Panel navigation should hide the following system files:
., .., ._.Trashes, .Trashes, .fseventsd, .Spotlight-V100, .Trash, System Volume Information, .HFS+ Private Directory Data*, .journal, .journal_info_block
We have just recently added the following to our Sept 30 2011 release:
.DS_Store, .apdisk and .com.apple.*
Chris
Great! Look forward to that then.
Marius
« Reply #21 on: 20 Sep 2011, 06:24 pm »
exactly the files I'm seeing in the display....
great.
Thanks Chris, James
Chris
terrycym
« Reply #22 on: 20 Sep 2011, 06:33 pm »
From the Windows world, could you also add  Thumbs.db  please?
Marius
« Reply #23 on: 20 Sep 2011, 06:40 pm »
coming to think of it: the extensions like .flac are always displayed. I wouldn't mind if that was left out, just like all the / and _ between numbers and titles.
Maybe you could have a look at that too?
Marius
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #24 on: 21 Sep 2011, 02:14 pm »
Hello
Those criteria have been added, in addition to *.pdf
Chris
terrycym
« Reply #25 on: 21 Sep 2011, 02:27 pm »
Hello
Chris
That's smashing, suoer, great!
And I didn't even mentioned the RWC either  :wink:
Marius
« Reply #26 on: 29 Sep 2011, 07:27 am »
this speaks for itself:
not there in Max by the way. Finder was hiding hidden files. Unhiding those this is revealed:
So the Bryston VFP still reveals those even when hidden. Otherwise it looks nice! Especially on the .....Ipad.
Thanks for that.
Marius
Chris
« Reply #27 on: 29 Sep 2011, 11:27 am »
Hi Marius,
You can get rid of the hidden files using delete on the network and then reboot.
james
Marius
« Reply #28 on: 29 Sep 2011, 11:37 am »
I know, had already done that... :scratch:
After that I hid the hidden files again, and they're hidden in finder (and Max) but the Max VFP shows them anyhow. Nevermind, eventually you'll sort it? Another thing: VFP also shows accented vowels as ?.  Suppé is Supp<?> Minor thing too, but would be nice to see that changed.
Marius
Hi Marius,
james
« Reply #29 on: 29 Sep 2011, 11:40 am »
Marius
Yes the VFP was kind of a last minute thing I thought would be fun so we should spend some more time working on it to fine tune it.
james
terrycym
« Reply #30 on: 29 Sep 2011, 11:53 am »
Marius
Hey Marius, do these characters display correctly on the real BDP-1 front panel?
I seem to remember seeing them too.
It would seem that between the two of us we'll get the BDP-1 product from a great product to exceptional product so long as the developers take on board some of our suggestions/bug reports. Yes?
terrycym
« Reply #31 on: 29 Sep 2011, 11:55 am »
BTW James, I'd be prepared to alpha test your upcomming disk drive thingy.
You need it testing on a real voltage supply - 240v that is!
Marius
« Reply #32 on: 29 Sep 2011, 12:23 pm »
you bet. :thumb:
I believe they do.
terrycym
« Reply #33 on: 29 Sep 2011, 12:35 pm »
you bet. :thumb:
I believe they do.
I thought as much.
Damn, the hard disk inside my VW car radio copes with acute & grave accesnts without issue.
Come on James, you'll have the Québécois compaining next and we can't have that, can we? (notice the accents?  :wink:  )
« Reply #34 on: 29 Sep 2011, 12:46 pm »
I thought as much.
Some of these issues are Linux based I believe but I will ask.  I know you are correct that we have to do as best we can to make the interface as responsive as possible but I honestly feel that sometimes it overtakes the whole point of the BDP-1 - great sounding digtal playback :duh:
james
terrycym
« Reply #35 on: 29 Sep 2011, 07:50 pm »
james
How do you get to this VFP in the latest firmware?
terrycym
« Reply #36 on: 29 Sep 2011, 08:16 pm »
Doh!
Solved it.
Firefox > Tools > Clear Recent History
Et voila, a new button!
MAX VFP
"Settings" is now screwed though
I can't select the different tabs as the navigation area to the left is now blank.
It's ok in the iPad, thank God, just Firefox v6.0.2 on Windows XP.
Anybody else suffering like this?
I guess there ain't many with the 1st October firmware yet?
terrycym
« Reply #37 on: 7 Oct 2011, 09:25 am »
Settings still not displaying correctly in Firefox.
I had to download yet another browser (Chrome) for it to work.
Is Firefox no longer supported?
What's the latest here as I've heard no answer on this
