is a sony str-DA1ES good to power 4 JBL L44 speakers ?
0 Members and 1 Guest are viewing this topic. Read 2377 times.
MikeCTM2
HI    i have a pair of JBL LX44 speakers  and i want to add a second pair, or i mean, one more to each side  (simple 2 channel set-up )
a guy in my city is selling a sony STR-DA1ES     could that power these 4 speakers in a stereo/2-channel set-up ?      If not, what receiver would be better ?
I'm currently using a simple Sony 2-channel amp/receiver
So, if i wanted to add these two additional LX44s to the 2-channel set-up, could i just twist in their speaker wires to each existing LX44's speaker wires   thereby, having my current Sony 2-channel amp power them all ( all four LX44 speakers )
i appreciate the insight
Re: is a sony str-DA1ES good to power 4 JBL L44 speakers ?
« Reply #1 on: 13 Sep 2011, 10:31 pm »
SPECIFICATIONS of the JBL L44's:
8 inch woofer, 5 inch mid range and 1 inch pure titanium tweeter
Nominal impedance: 8 ohm.
Input sensitivity: 91dB/W/m.
Frequency response: 40Hz-25kHz
Recommended input power: 10W-150W.
SPECIFICATIONS of the Sony STR-DA1ES:
90 wpc all 5 channels at 8 ohms.
Generally the ES series were well built.
So electrically they’re well matched.  If listening in a 12 ft x 20 ft x 8 ft room, you can expect to reach 114 dB (damn loud, plenty loud to break your lease or get a visit from law enforcement).
MikeCTM2
STR-DA1ES
« Reply #2 on: 14 Sep 2011, 10:06 pm »
Can the Sony STR-DA1ES  run in a simple "stereo" mode putting TWO channels to the left and TWO channels to the right?
That's with ALL 4 channels having equal strength.  In the "5 channel" mode of the DA1ES, = 1 channel is the 'center' and 2 channels are "main/stereo" channels  and then 2 channels are "rear/backgrounds"   <---correct ?
srb
« Reply #3 on: 15 Sep 2011, 07:28 am »
The Sony STR-DA1ES does not appear to have a "5-channel stereo" mode, in which the front L/R amplifier channels and rear surround L/R amplifier channels would both receive an identical stereo signal (and the center amplifier channel would receive a mixed mono signal), as do some receivers like Rotel, Denon and others.  The Sony STR-DA1ES only appears to have 5-channel DSP modes which would not give the same stereo L/R signal to the surround channels, but instead send them a reduced level delayed ambience signal.
If you were to connect each pair of 8 ohm speakers in series for a 16 ohm nominal load to your present receiver, it would probably produce limited power (although it would be a safe load).  If you connect each pair of 8 ohm speakers in parallel for a 4 ohm (or less) nominal load, the receiver may not be capable of driving that lower impedance load at decent volume levels without overheating.
The Sony STR-DA1ES (and maybe your present receiver?) has an impedance selector switch that should be set to the 4 ohm position if you are using less than an 8 ohm speaker load as would be the case with 2 - 8 ohm speakers in parallel.
Many solid state amplifiers (without transformer coupled outputs) will output 40% or more power at 4 ohms than at 8 ohms, however on amplifiers like the Sony STR-DA1ES that have an impedance switch to prevent overheating and unstable operation with less than 8 ohm loads, they actually have a lower rated output (80W/ch) at 4 ohms than at 8 ohms (100W/ch), due to the switched in current-limiting circuit.
« Last Edit: 15 Sep 2011, 02:15 pm by srb »
