New caps for older amps
0 Members and 1 Guest are viewing this topic. Read 1473 times.
redbook
  • the music is the blood...........
« on: 13 Sep 2011, 08:56 pm »
James could you tell me if I send in my4B ST for a check up would the caps be replaced with the same or better versions? :tempted:
  • The Demo is Everything!
    • http://www.bryston.com
Re: New caps for older amps
« Reply #1 on: 13 Sep 2011, 10:33 pm »
Only if they needed replacements.
James
redbook
« Reply #2 on: 14 Sep 2011, 03:11 pm »
Thanks James. I assume that there wouldn't be a better cap choice over the original design.  :bawl:
« Reply #3 on: 14 Sep 2011, 04:24 pm »
Correct :thumb:
james
SoundGame
« Reply #4 on: 14 Sep 2011, 06:06 pm »
Now speaking of new caps, my 3B-ST had a mechanical hum, no matter what outlet it was plugged in, tried a couple different houses as well.
I sent it into Bryston - they replaced the transformers and the filter capacitors.  Since my 3B-ST was not one of the latest ST versions, they installed the latest ST transformers and capacitors.  So it turned out the the capacitance was increase by 12,000uf.  Output power tested at 160w+160w, the 3B-ST spec. is 120w+120w.  (all under warranty - only cost me the one way shipping to them).
In short, if there is a repair need on your amp - Bryston really takes care of you.  They will fix everything that needs to be fixed and will use the latest parts for the model.  Note: they did not install SST transformers nor capacitors - believe me, I asked... :D
