Back Loaded Horn / horn software? Is there any that is easy to use?
0 Members and 1 Guest are viewing this topic. Read 3470 times.
jparkhur
Is there anything out there..  Or do i need to get out my calculator and pencil.....
JP
ultrafi
JP,
Look up the horn response analysis program from David McBean.  That's generally the tool of choice.
Larry
Larry D. Moore, Esq.
Ultra Fi
planet10
  • Frugal-phile (tm)
    • planet10-hifi
If as in easy to use, a program that doesn't require you to know how a horn works no...
But given that you do, i'd recommend Martin King's software. http://quarter-wave.com/
dave
rjbond3rd
For ease of use, AJ Horn is the best but it's not cheap.  However, if you really want to get started designing BLH's and you want the simplest tool, it is the one.  I have spent so many hours that it's been well worth the purchase price.
MJK is more advanced but takes more time to learn (worth it though, if you are super serious!)  I use both.  As mentioned, Horn Resp is perhaps the overall most popular (and free).
jparkhur
Thanks guys, very helpful.  Jon
