Audio/Video Gear and Systems
Tube-o-phile Circle
JakeJ
Preamp with a tube integrated amp
0 Members and 1 Guest are viewing this topic. Read 1931 times.
50jess
5 Sep 2011, 08:05 am »
If I connect an external preamp to a tube integrated amp, will the external preamp bypass the preamp section of the tube integrated amp and render the preamp tubes (using NOS tubes) of the tube integrated amp useless?
decal
Hearing is believing !!!!
Re: Preamp with a tube integrated amp
5 Sep 2011, 10:18 am »
It depends on the design of the integrated, check your manual to see if your amp has this feature. My Rogue Audio Tempest can be configured as a power amp only. If you don't have a manual, you should really contact the manufacturer and ask them.
Tube-o-phile Circle
JakeJ
