EAC filenames
0 Members and 1 Guest are viewing this topic. Read 1680 times.
EAC filenames
« on: 2 Sep 2011, 08:53 pm »
Hopefully this should be easy.  Before the new computer everything worked fine.
When I rip and convert a CD the tracks end up in my library folder but they are all scattered.
They used to go into an new file of the file of the artist.
Under EAC options>filename do I just %artist% %album% track% ??
and do I check various naming scheme?  if so, what should go there?
thanks much
Big Red Machine
Re: EAC filenames
« Reply #1 on: 2 Sep 2011, 11:22 pm »
Rich, I have:
%A - %C - %N - %T
and then %C %N %A %T in the second box on the right.
This may be inconsistent with others but has been my set-up for years.
Thump553
Re: EAC filenames
« Reply #2 on: 4 Sep 2011, 11:15 am »
Everyone has their own filing system, but I put everything (in Music folder) in seperate folders by Artist then Album then subfolders for CD1, CD2, etc. if necessary.  For compilation albums, Various Artists then Album.  It makes a manual search easy.
Re: EAC filenames
« Reply #3 on: 4 Sep 2011, 12:53 pm »
Thanks guys.  Pete the newer version of eac uses actual descriptions instead of A, C, etc. so not sure what A referenced to.
Thump, that sounds like how I want them Folder (music library)> Folder (Artist) > Folder (Album title) >Folder (track titles)
I just tried something but it keeps dumping the title tracks into the music library folder.  I then have to create new folders and arrange them myself.  :(
jlafrenz
Re: EAC filenames
« Reply #4 on: 4 Sep 2011, 02:30 pm »
Try using slashes between the folder name and the artist and title instead of just the dash.
Re: EAC filenames
« Reply #5 on: 4 Sep 2011, 05:36 pm »
You da man  :thumb:
The mouse over helps in this regard too, but of course I didn't believe that  :P
