Favorite way to hook up speaker wire to those tiny vintage connectors!
0 Members and 1 Guest are viewing this topic. Read 7980 times.
orthobiz
Push-connectors, screws with little room for anything...the vintage connectors on the back of vintage amps/receivers are tiny, like even 20 gauge wire is a hassle. Does anyone make a "connector for connectors?" Maybe something with a banana female to a quality skinny tip? Something that's not DIY?
Paul
Brett Buck
Paul
   I see them all the time on eBay but I presume that there are regular suppliers. For example:
http://www.ebay.com/itm/8-Banana-Spade-Fork-Plug-Fisher-80-202-Eico-Dynaco-/330504308886?pt=LH_DefaultDomain_0&hash=item4cf3978896#ht_2981wt_1165
     20 gauge wire is sufficient for most vintage equipment but I use spade connectors, not the bare wire ends.
    Brett
S Clark
Doublej
http://www.amazon.com/PAIR-ATLONA-SPEAKER-CABLE-CONNECTORS/dp/B000MM2PXG
There are higher end versions of these as well.
Possibly these?
http://www.monstercable.com/productdisplay.asp?pin=599#null
Or you could just use single strand cat 5 network cable as your speaker wire.
pansixt
Paul,
I like using no connectors, but as with my Dyna amp and Kimber speaker wire,
I had to go with spades. I'm not bothered with gold plating or high quality.
Eventually, I'll have Frank upgrade the Dyna and part of that is better binding posts.
But like Brett, I will stick with spades. I just don't like bananas or pins personally.
James
