Bang & Olufsen Beogram RX help please...
0 Members and 1 Guest are viewing this topic. Read 5138 times.
orthobiz
« on: 1 Sep 2011, 10:54 pm »
Someone gave me an RX turntable in good cosmetic condition. Can someone please help me:
1. A service manual? (It's not on VE)
2. The left channel is extremely weak, I can hear a "flash" of normal volume just before the needle hits the groove and just as it is raised from the groove. I think the mute mechanism might be at fault.
3. The dustcover is missing the "axles," any idea of a good McGuyver fix?
Paul
*Scotty*
Re: Bang & Olufsen Beogram RX help please...
« Reply #1 on: 1 Sep 2011, 11:11 pm »
If all you need are steel pins you could use stainless steel welding rod. It comes in a variety of diameters one of which may be the correct size. Short metal rods are also available in some hardware stores in a number of sizes as well.
Scotty
PRELUDE
« Reply #2 on: 2 Sep 2011, 12:02 am »
Try this site and you might get lucky.Peter in sound smith has been working with B&O for a long time.
http://www.sound-smith.com/
orthobiz
« Reply #3 on: 2 Sep 2011, 02:01 am »
The section on
one channel out troubleshooting
says I have a bad cartridge! Thanks Prelude!
Paul
PRELUDE
« Reply #4 on: 2 Sep 2011, 02:18 am »
The section on
Paul
Your welcome :thumb:
They rebuild also but I do not know about prices.
orthobiz
« Reply #5 on: 2 Sep 2011, 11:05 am »
Actually, I think you really have to buy new, they can only rebuild select MMC models, not the MMC-3 I have. I also found aminaaudio . com; they rebuild for a flat fee of 100. I'm leaning towards a middle line SoundSmith; if I cannot revive the table I can always buy the 50 dollar mount and use it as a conventional pickup.
Having plugged the cartridge in rotated 90 degrees (what a weird experience!) and having the sound move to the other channel rules out a problem with the muting switch or the wiring...I think the momentary blip of higher level sound as the needle hits the groove may be a failing suspension/internal wiring.
Paul
orthobiz
« Reply #6 on: 5 Sep 2011, 04:17 pm »
Ordered the entry level B&O replacement from SoundSmith. The guy on the phone assured me it will happen in two weeks. Orders taking as long as a year have been reported! Still no good advice on the dustcover. The RX-2 manual is online but differs slightly from the RX, enough to make it hard to figure out.
Anybody got a pic under the dustcover lip?
Paul
