Music and the Human Ear
0 Members and 1 Guest are viewing this topic. Read 1328 times.
Mag
« on: 1 Sep 2011, 04:55 pm »
There was a small disagreement as to whether audiophiles can hear music at 20 khz. I made the claim that I could hear at 20 khz and that it has a holographic effect. As well it takes on a omni-directional quality.
Of coarse not all music has 20 khz content. With my collection it is usually found in Electronic music.
Here is a good article on the subject, that explains in better detail. 8)
Link:
http://www.silcom.com/~aludwig/EARS.htm
rollo
  • Rollo Audio Consulting -
Re: Music and the Human Ear
« Reply #1 on: 1 Sep 2011, 05:02 pm »
  Interesting read, thanks. Just reinforces my belief that one size does not fit all as our bodies are just not equal. Only way to tell is with your own ears.
charles
SMA
John Casler
« Reply #2 on: 1 Sep 2011, 05:20 pm »
Link:
Hi Mag,
The most interesting point of your suggestion is that you find the "higher" frequencies to have an "omni-directional quality", when the higher frequencies tend to be perceived with greater directionality in general,  :scratch: and it is the lower frequencies that have spatiality.
That is, it is the higher frequencies that give us "pinpoint" imaging and location.  Sounds like you are hearing a more diffuse dispersion of those frequencies.  Maybe from a very lively room.
As well if it is with mostly electronic music, the perception may be due to a "phasing" of those frequencies which could cause them to be perceived as more diffuse.
Mag
« Reply #3 on: 1 Sep 2011, 11:50 pm »
Hi Mag,
The article gives the reason for that in paragraph 4, Location.
Anti-aliasing filters used to record at those freq. causes transients to be blurred, smearing ability to discern direction, and phase issues.
Which compliments the ambience of Electronic Music quite well. :smoke:
