0 Members and 1 Guest are viewing this topic. Read 4074 times.
Something else I'm working on ... just found the 'magic' in the crossover today. Can you say less than .1% THD from 150hz to 20K!
Looks like a bold & brawny little iron. Can't wait to hear them. The 17th or 24th may both work for me. merrev
Hey Ryan,Have you considered hitting the baffle edges with a roundover? It appears that you went to a lot of trouble controlling standing waves and the waveguide and putting a roundover. That should improve the imaging a bit...
Diffraction is from transverse waves moving across the baffle face and scattering when it hits the terminus or edge. With a waveguide of this size you don't get those transverse waves and thus edge diffraction isn't a concern. Measurements confirm this as well. So a roundover would have no effect on performance in this case. Even in typical designs, a standard 1/2" or 3/4" roundover does very little to control edge diffraciton. You need to get up to the 2" roundover range to eliminate it, or 3" as I've designed into my Cirrus.
Ryan, I can't say for sure but I will try and make it. The 24th is better for me. I might be enticed by a nice cigar and dram of Scotch . Looking forward to hearing the latest systemSturgus
1/4 wavelength principle would still apply. ( I have a 2" roundover on mine. ) Looks like an interesting design. I wish I could hear them.BTW I still have those ob2x you sold me. Too bad they don't see much use though.-Tony
Great, look forward to seeing you ... these suckers are a 'bookshelf' with balls. 8" woofer in about 1.2 cu/ft, walls made of 10 layers of hardboard laminated with marine epoxy over jigs to pre-tension them. I have a hunk of the wall that I think will stop any handgun round, and intend to find out
