First Build with X-LS Kit - pics
0 Members and 1 Guest are viewing this topic. Read 13609 times.
Danny Richie
Re: First Build with X-LS Kit - pics
« Reply #40 on: 12 Sep 2011, 04:33 pm »
Can I assume the X-LS Encore's tweeter will leapfrog the A/V-1 tweeter?
Yes. The Encore tweeter is one of the best dome tweeters available.
Vedder323
  • vinyl reviews and more, check out Newrecordday.com
    • New Record Day
« Reply #41 on: 12 Sep 2011, 05:24 pm »
Where do you get the kits for the X-LS?
Danny Richie
« Reply #42 on: 12 Sep 2011, 06:22 pm »
You can get them by calling GR Research and ordering them.
940-592-3400
freerider
« Reply #43 on: 21 Sep 2011, 12:59 pm »
So out of curiosity, I measured the resistance of my X-LS and my Acoustic Research bookshelves to see the difference.
X-LS: 7.3 Ohms
Acoustic Research: 3.8 Ohms
This really surprised me, because I assumed the brick and mortar cheap speakers would be 8 ohm speakers.  Now I'm wondering if the difference has anything to do with why I need more power to drive the X-LS speakers for the same relative dB.
« Last Edit: 21 Sep 2011, 02:14 pm by freerider »
Danny Richie
« Reply #44 on: 21 Sep 2011, 01:58 pm »
X-LS: 7.3 Ohms
This really surprised my, because I assumed the brick and mortar cheap speakers would be 8 ohm speakers.  Now I'm wondering if the difference has anything to do with why I need more power to drive the X-LS speakers for the same relative dB.
At the same volume setting your Acoustic Research speakers are getting twice as much power.
freerider
« Reply #45 on: 23 Sep 2011, 05:19 am »
Finished product.
freerider
« Reply #46 on: 23 Sep 2011, 05:27 am »
For the back I chose some heavy duty binding posts.
Ron
« Reply #47 on: 23 Sep 2011, 11:18 am »
  Your finished X-LS speakers look very nice. Good job!  :thumb: What type of finish did you use on them?
Also, since they have had time to break in more do you think they sound better now than they did at first?
freerider
« Reply #48 on: 23 Sep 2011, 01:19 pm »
Thanks, it's just textured spray paint covered with satin black spray paint.
They sound awesome!  Best sounding speakers I own by far.
