Have a problem with my 5.1
0 Members and 1 Guest are viewing this topic. Read 3131 times.
DennyH
    • http://Digiartwork.com
« on: 19 Apr 2004, 02:55 am »
The woofer quit on one of my (4) 5.1's. Tweeter still works fine. I have emailed Nohr customer service about this, but in the meantime, have any of you had this happen and what did you have to do to get it fixed/replaced. The website says that the warranty is 5 years and I have only had the speakers for less than 1 year.
Denny
Bryan
« Reply #1 on: 20 Apr 2004, 08:25 pm »
Have you opened up the speaker to make sure there isn't a loose connection? Haven't had any trouble with my 5.1s as of yet.
DennyH
« Reply #2 on: 20 Apr 2004, 11:48 pm »
I thought about doing that, but only after hearing from Michael. I dont want to screw up any warrantee that might apply.
Thanks for the reply. I was beginning to wonder if I was going to get one  :? .
DJ
HT System:
HK 525
SVS PB2+
Norh 5.1 Front and Surround
Norh Prism 4.1 Center
Pioneer 563 Universal Player
Hitachi 53SBX59B
PJ
« Reply #3 on: 21 Apr 2004, 04:32 am »
I agree with Bryan.
Although it's possible, drivers VERY rarely fail unless they are damaged through misuse.
I would think that one of the driver connections has most likely come loose.
PJ
« Reply #4 on: 21 Apr 2004, 04:33 am »
I agree with Bryan.
DennyH
« Reply #5 on: 22 Apr 2004, 02:31 am »
Very carefully checked all connections tonite and they are all tight. Any other ideas, since I still havent heard from Michael  :? ?
DJ
Bryan
« Reply #6 on: 22 Apr 2004, 02:23 pm »
Unfortunately I have no other ideas. Try email Namphung and see what she says. My guess now is either the driver has gone kaput or something in the crossover has.
DennyH
« Reply #7 on: 23 Apr 2004, 12:01 am »
They are having me check the crossover with an OHM meter. I have to borrow one this weekend and hopefully it will narrow down the problem.
DJ
DennyH
« Reply #8 on: 27 Apr 2004, 07:49 pm »
Meter indicated that its a bad driver. NOW I have to send it to them to confirm that its a bad driver. Maybe I will have a speaker back in service by the time The Return of the King ( SE) comes out.  :(
DJ
