0 Members and 1 Guest are viewing this topic. Read 5043 times.
I do not mind buying all of the gear used so as long as the gear is well made I should be fine. Is a GREAT amp from 5-10 years ago just as good as what is currently available new but just doesn't have the appeal or new bling? What about a pre-amp that was all the rage a few years back? Is it clearly bested by a new one at the same price of that older used model? Does the trickle down technology really work? Is it more prevalent on the pre-amp side or the amp side? Or, do you feel that they have both progressed at the same rate? Is it just different now but not really noticeably better?Thanks for your input!James
Does a Stereophile Recommended Components Class A piece of equipment from the past still compete in Class A or is it more commensurate with something lower?
Here are the used Line Stage pre amps on my shopping list. De Havilland Ultra Verve 3 with remote. I saw one on Audiogon for $1200. I bet you could swing a deal on new. Dodd Battery Linestage Preamp (not to be confused with the Passive Line Stage) with remote. I have seen as low as $1700 used. Conrad Johnson Premier LS17 Linestage with remote. I have seen as low as $2200 used. Each of these has thier own sound. You could google and find many reveiws.
