HT2-TL's with a Belles 350A amp and CJ PV15 preamp?
0 Members and 1 Guest are viewing this topic. Read 2166 times.
dgriff
« on: 28 Aug 2011, 06:02 pm »
I have the Belles 350A Reference power amp and a Conrad Johnson PV15 preamp. They should work nicely with the HT2-TL's but I was wondering if anyone has had any experience with Salk speakers paired with Belles or Conrad Johnson equipment.
Carl V
Re: HT2-TL's with a Belles 350A amp and CJ PV15 preamp?
« Reply #1 on: 28 Aug 2011, 08:06 pm »
HT1 with cj el34 based amps.
Borrowed HT2 for a weekend 5 years ago with 6550 & el34.
1st the speakers are revealing en'uff to communicate the differences
between these two tube types as well as borrowed cj integrated.(s)
the CAV50 & the ET250S
So, If you like the sound of tubes you're good to go.  And I know it goes
against the grain of some but the tubes with their subtle euphony makes
a good case for smoothing the SEAS metal driver....imho.
In all honesty the more expensive ET250 was the best combination.
It had most of the check list of wants & needs under control.  All the others
were darned nice but you were picking & choosing amongst the +/- of
the gear.
good luck have fun & euphony isn't always a bad word.  And truly neutral
is a noble quest & most times it's ephemeral...ymmv, imho  yadda yadda
Nuance
« Reply #2 on: 29 Aug 2011, 01:07 pm »
OgOgilby has a great SS CJ preamp and he loves it.
dgriff
« Reply #3 on: 2 Dec 2011, 09:05 pm »
Update - I've had my new HT2-TL's in my system for a little over a week and I'm blown away.  The HT2-TL's have brought my system up to a new level. The HT2-TL's are a perfect fit IMO.  :D
OgOgilby
« Reply #4 on: 4 Dec 2011, 03:19 am »
Yes I do.
The HT2-TL's just get better as you upgrade your electronics since they are very revealing.
