WTB: Used 2-channel preamp under $300
0 Members and 1 Guest are viewing this topic. Read 1628 times.
jeff442
« on: 28 Aug 2011, 01:57 am »
I know little to nothing about preamps but own a pair of VMPS RM30's and am looking for a good preamp here (or on Audiogon) to pair with an Emotiva ERC-1 CD player.  Any suggestions?
Sparky14
Re: WTB: Used 2-channel preamp under $300
« Reply #1 on: 28 Aug 2011, 02:04 am »
Just go find a used Emotiva USP-1. I'm pleased with mine.
Jlappy
« Reply #2 on: 28 Aug 2011, 06:55 am »
jeff442,
sounds like you need an amplifier also?  or do you have an amp that you didn't mention above.  so i am wondering if you need an integrated amp.  just looked on Audiogon there is a few in your price range.   http://buy.audiogon.com/cgia/fsb.pl?intatran
Good luck on your search.
cheers,
Jim
HT cOz
« Reply #3 on: 28 Aug 2011, 11:45 am »
Look for an Onkyo A-9555 on the bay or audiogon. You will be able to find one for very near that price and it will serve you well for a long time.
roymail
  • Roy in TX
« Reply #4 on: 30 Aug 2011, 08:16 pm »
Can you tell us about the gear you plan to use with it, and we can advise you better?  No doubt you can put together a sweet sounding system for not a lot of $$$.  :D
cliffy
« Reply #5 on: 30 Aug 2011, 09:04 pm »
Check your PM.
jeff442
« Reply #6 on: 1 Sep 2011, 05:44 am »
Thanks for the suggestions and PM's everyone.  Looks like I'll be anxiously awaiting the UPS truck with my Musical Fidelity X-P100!
