370BX bolts (on Cornet2)
0 Members and 1 Guest are viewing this topic. Read 1485 times.
Clive
« on: 27 Aug 2011, 02:03 pm »
I've just noticed that the 370BX transformer on my Cornet2 has the bell ends secured via 3 bolts which are insulated from the laminations and 1 shorter bolt which is not insulated.  Is this normal or do I have something wrong with the uninsulated bolt?
Clive
Re: 370BX bolts (on Cornet2)
« Reply #1 on: 27 Aug 2011, 06:05 pm »
Can someone with a Cornet2 take a look at their mains transformer and tell me whether all 4 bolts passing through the laminations have nylon insulators between the bolts and the TX?
Clive
machine
« Reply #2 on: 27 Aug 2011, 06:23 pm »
Only 3 insulated on both my Cornet 2's.
The uninsulated one has the grey grounding wire attached.
Good idea to run this wire inside to the common ground point as describe in numerous posts here.
Fixed hum issue with both my Cornets.
Clive
« Reply #3 on: 27 Aug 2011, 09:24 pm »
Perfect, many thanks!
