0 Members and 1 Guest are viewing this topic. Read 16761 times.
Thanks guys, I appreciate the replies.Chris, I bought about my R-114 new, and it's nearly mint. It's in my modest system which is used every day. It still sounds very strong for 50wpc. It has pre outputs and amp inputs. I've used both of them separately over the years, and never had a problem.Did you also sell Nakamichi Stasis receivers, too? I came very close to buying one of those. I wish they still made receivers of this quality.
I think they do but you are not going to like the price on this one:http://www.magnumdynalab.com/2-channel-audio-receiver-md209.htm
It's not easy to find a single ended tube receiver and I was fortunate to stumble upon this early EL-84 Rotel/Martel. At 10wpc it's a good match for HE full range drivers.
The VSX-D912 is no longer available unless you find one on ebay and it may not be US voltage.
The points of that thread essentially is that speakers make more of a difference to the overall sound than amplification and that's how your system budget should be reflected, to which I agree 100%. But can the build quality of a $200 receiver be expected to hold up to a $2000 integrated? Obviously not. And in this case the speakers used were very efficient, thereby not requiring beefy (expensive) power supplies. The thread comes from a speaker manufacturer, so you should expect an extreme example like this.
The VSX-D912 is no longer available unless you find one on ebay and it may not be US voltage. I'd be surprised if it beats the digital Panny receivers.
