0 Members and 1 Guest are viewing this topic. Read 11812 times.
This is exactly what I have done (although for other reasons which aren't yet realized). I also would recommend this to the OP.
Long sold that unit off. A tad too artificial in its audio supercharging and it did not reduce noise for me. It was a very exciting unit to play with but not one I could live with. Very happy with the BPT unit and maybe next year I'll have Dave make me a super-UberBuss!
Yes, dedicated lines are connected "together" at the breaker panel, but there are ways to further isolate the circuits by placing them on the opposite phase from refrigerators, washer/dryer, AC, etc. etc. The only way that a piece of gear would be more isolated would be via the use of an isolation transformer, but you still (unless I've been misinformed) have an ultimate connection to the panel via the neutral connection.Regardless of AC line conditioners/filters, whole house surge protection, isolation transformers, or other noise-reducing schemes, we are still at the mercy of the supply transformers in our neighborhoods. Some have it better than others if they live in a rural area with few end users, but we're still talking about relative noise reduction rather than true isolation. There are the lucky few, however, that don't share a supply transformer with any neighbor, but how many of them are audiophiles concerned with dedicated circuits and common mode or differential mode noise reduction?My advice remains for the original poster....buy another Powercell 4, and separate his digital gear from his analog gear. It's not a perfect world.
Well, you really can't separate your audio gear from all other gear without some type of transformer, because there's 240V equipment that uses both phases. I have my equipment on an isolated ground system in metal conduit, but this still only protects from noise from the panel to my system. Now, if you had a transformer and used the correct wiring, you could get noise reduction for common-modes. That would be great, but expensive.
I would not sell my Powercell 10SE, because it affects some components unlike any of the other PLCs. But I do agree with you, based on the effect used on some of my components, that it "supercharges", and may not be what is needed, or desired. I would suggest get one of the smaller Powercells, and try it after the BPT, on each component. I learned a long time ago that one type of PLC, or power cord, is not best for all components. That route is for the more naive audiophiles. Big transformers like BPT, Torus, Equitech, R. Grey, are an exception, but I hardly consider them a PLC.If you get another UberBuss, please insist that PI Group uses premium parts. I got an earlier one that had defective Furutech duplexes. They had very little spring tension to hold the plugs, and would arc. Replacing with better duplexes solved the problem. It was a fault of Furutech, and not noticed by PI Group.Other than that, the UberBuss is fine sounding product!
Yeah, that was a bummer on the Furutech. It turned out that they made a run of improperly heat treated contacts and you were unfortunate enough to get receptacles from that run... me, too The new Furutech N-1 receptacles have a bodacious grip on blades and the overall quality of Furutech is topnotch. Sorry you went through the hassle of iffy product. It's that whole imperfect world scenario, I guess.Dave
Dave,How did you resolve this problem for the folks that bought your products with the bad Furutechs installed?rw
That seems to be an elusive goal for AC plugs, but nonetheless, another factor in sound quality.Gutwire makes a wall plate named The Lock, which clamps onto the cord plug. A very good idea, but their product is very expensive... like $700.00 !Here is some pictures:http://www.6moons.com/audioreviews/gutwire4/hero_cant.jpg
Call me crazy, but I'm seeing Medex or MDF stack glued and drilled with forstner bit and then epoxied on top of a stainless steel receptacle cover for a whole helluva lot less than $700.00. You could glue ERS cloth inside the hole to make a friction fit for the plug body, too... or set screws.Don't get me wrong. As an independent businessman in tha audio field I am all about someone making a buck, but $700.00??? Dave
