0 Members and 1 Guest are viewing this topic. Read 32917 times.
Do you have a passive attenuator somewhere in your bag of tricks? The BDA-1 potential will not be realized unless it can be released from preamp bondage. A balanced attenuator would be ideal, but a single ended will do.
I have no doubt that your preamp is excellent. My contention is that an added stage of gain is not needed or required. The BDAs output stage is all that is needed. The Bent would be excellent for just this purpose. Less is more.
Great write-up Ted.I look forward to reading more over the coming days.George
Thanks. Remember that this is NOT a DAC comparison, just a front end/transport comparison, so issues like ability to handle complex music, and even soundstage width and depth are much more, to me at least, denizens of the DAC's ability rather than the transport's. I will spend one night comparing my Gold to the BDA, using same transport, but this will be on a separate thread, and will also be somewhat cursory.
I guess I'm saying that I'm very aware of all those aspects (I'm a huge imaging guy myself) and don't feel it necessary to comment on them (although i'll pay more attention tonight) because I don't feel much if any changed in those areas. Likely my tweeked out Mac Mini setup is quite a bit closer to the BDP than the Transporter was.
Konut, Thanks. To be perfectly honest, I was look forward to this when George initially offered to send the gear. Then, as the time approached, i began to get overwhelmed with other stuff and felt as if this evaluation would make my head explode. But it's done none of that...I really look forward to each evening's listening/switching session. This is fun.Terry, I think the cables make a big difference, and it doesn't surprise me that the DIg4 could be called clinical in some systems. There are two reasons for this, one: the cable needs a boatload of break-in (like 400-500 hours as you well know by your review of Morrow cables), and two: the resolution could tip the synergy too far left. In my case, i think the cable is very neutral and amazingly resolute, but thanks to George for putting in the time to break this in.
I use a 2009 Mac Mini (8GB, SSD) as my primary music server, running SL 10.6.8 and using Pure Music 1.8's integer stream support into an Antelope Gold 24/384-capable DAC. It is my best music to-date.George (zybar) will be sending me his BDP-1 for demo/loan in a couple weeks, and I'll use it into the Gold via AES/EBU (DH labs D-110). Stay tuned.
