0 Members and 1 Guest are viewing this topic. Read 33071 times.
While the DAC absolutely has a bigger influence over the areas you mentioned above, I have found that all of that is definitely impacted by what feeds the DAC. For example, I was stunned at the difference in performance levels between the Modwright Transporter and Bryston BDP-1. The two didn't sound even remotely close in the areas of soundstage, macro and mirco details, realism, and overall ability to draw one into the music. The BDP-1 was far superior in every way.
Ted,While the DAC absolutely has a bigger influence over the areas you mentioned above, I have found that all of that is definitely impacted by what feeds the DAC. For example, I was stunned at the difference in performance levels between the Modwright Transporter and Bryston BDP-1. The two didn't sound even remotely close in the areas of soundstage, macro and mirco details, realism, and overall ability to draw one into the music. The BDP-1 was far superior in every way.George
Ted,Thanks for the review. Any comments on interface, remote ap comparisons, album art, lp info input and other non-SQ/usability issues. Thanks- Doug
the later 2011 Mini sounds better than either the 2009 or 2010, even though it has to deal with a noisy internal power supply.
Simon,That is very interesting. I have never liked the optical out of the Mini; to each his own.
Sure wish someone could get a Mach2 music server to you Ted. That would be a good comparison since the Mach2 is about the same price as the Bryston.
Headshrinker2,The BDP-1 was a 90 on my scale, while the best setup to-date for my Mac Mini is an 85. I am not yet ready to make a change due to the open issues surrounding my Hynes PS upgrade. The lesser Hynes tour ps took my Alix Linux box from say a 65 to an 80 (however, it was woking from a much cheaper stock ps, and everyone knows the last few points are always the toughest).My point system is not at all scientific, but is just a bit of a quantification of gut feel, frankly, and I take points off for features missing (BDP loses points for not having DSD, 384k and NAS capability..which would make it perfect.) It beats the Mac Mini in noise floor and jitter performance (as far as I can tell).ADDDENDUM: I failed to follow up on one aspect of the BDP vs Mini performance that had been asked of me.....complex music. I didn't throw bombastic symphonies at it but played Mahler's 4th (Ivan Fischer, Channel Classics 24/192) and Shostakovich's 5th (Cleveland Orchestra, Telarc SACD rip at 24/176k). I also used a Bill Frisell cut from gone, like a train that gets a bit congested (great tonality on that album!!). In each case the BDP-1 sailed through with less fatigue and less congestion and timing issues than the Mac Mini via USB. I simply chalk it up to my jitter argument ; i.e jitter to me sounds like what looking through sunglasses in the rain looks like...slight smearing and halos. And if you follow that analogy, if you are watching one figure move, it's not nearly as confusing as watching many figures move.
What I'd like to see is a comparison of the BDP and the PK100. They have the same beginnings, different execution. The BDP is a little more than 2X the money; does it sound 2X better?
