Squeezecommander For Touch on Android Help
0 Members and 1 Guest are viewing this topic. Read 1357 times.
cloudbaseracer
« on: 23 Aug 2011, 01:55 am »
I am looking for a tutorial for the Squeezecommander app on my Droid X.  This stuff was obviously written by a geek because some of the things are not that intuitive at all.  Does anyone have a simple, easy to use but thorough tutorial?
James
cloudbaseracer
Re: Squeezecommander For Touch on Android Help
« Reply #1 on: 27 Aug 2011, 04:45 am »
Well I had hoped at least someone else on here would be using the Squeezecommander app and able to point me in the right direction.  I am willing to try another remote program for the Touch on Android if you guys have any suggestions?
golfugh
  • Dead Can Dance - Into the Labyrinth
« Reply #2 on: 27 Aug 2011, 05:28 am »
Don't have a tutorial, but if you have questions I can help.  Been using it for over a year through all current updates.
Mark
datman
« Reply #3 on: 27 Aug 2011, 06:17 am »
You might want to try the Logitech Squeezebox App. I am using it and it works quite well.
eclein
« Reply #4 on: 27 Aug 2011, 10:11 am »
Cloud- I recently got a new phone, Droid 3 and also only use the Logitech app now..its free..and after a few updates they have it working quite well. Go for it....Good Luck
