Tang Band 1772
0 Members and 2 Guests are viewing this topic. Read 1919 times.
jparkhur
Tang Band 1772
« on: 22 Aug 2011, 09:49 pm »
Has anyone used this in a back loaded horn.  If I pick these up, does the following look like a good plan.  See link.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-893
http://homepage.mac.com/tlinespeakers/FH/download/Chang-MBVR-map-170608.pdf
Thanks jon
Scottmoose
Re: Tang Band 1772
« Reply #1 on: 26 Aug 2011, 08:20 am »
As I've mentioned elsewhere (no reason you should have seen it though) that cabinet will not function properly with the 1772. Like several other cabinets I did for the FH site using the 7E series Fostex units, it is currently obsolete, and due either for a redesign, or removing entirely as time permits.
