Disputed data sheets: 2SC2509
0 Members and 1 Guest are viewing this topic. Read 1774 times.
Niteshade
    • Niteshade Audio
« on: 21 Aug 2011, 10:49 am »
I was hoping that the 2SC2312 would be a good substitute for the obsolete 2SC2509. According to some data sheets yes, others no!  :scratch:
One data sheet has the pinout: (1) Base (2) Collector (3) Emitter
Another: (1) Base (2) Emitter (3) Collector
I have since found a 2SC1945 and will look up some data on it. Unfortunately, I have 2SC2312's here.
It puzzles me how different data sheets can have different pin-outs for the same part!
Niteshade
    • Niteshade Audio
Re: Disputed data sheets: 2SC2509
« Reply #1 on: 21 Aug 2011, 11:03 am »
Think I found my answer:
http://forums.qrz.com/showthread.php?185514-2SC2509
Look out for bogus data sheets! The 2SC1945 should do the job.
BTW: One of the data sheets that's wrong is from Toshiba.
