Ram East modded Panasonic saxr 45 for repair or parts.
0 Members and 1 Guest are viewing this topic. Read 2078 times.
Ears
Has aftermarket 3 prong IEC connector for better power cord , Jensen 4 pole main power supply cap , solid silver Audio Consulting cotton covered wiring for all channels , WBT speaker terminals for 2 channel , and digital in Bybee.  May also have other small caps replaced , and comes with two remotes , original box and manual.
Powers on and makes a high pitched ticking sound like a short  , and then shuts itself off.
I forgot that all channels have new plastc binding posts instead of the spring clips also , and the S video connectors are gone to make room.
Best Offer takes it.
Greg
« Last Edit: 17 Sep 2011, 06:18 pm by Ears »
Ears
Re: Ram East modded Panasonic saxr 45 for repair or parts.
« Reply #1 on: 17 Sep 2011, 06:16 pm »
Some Pics
jackman
« Reply #2 on: 17 Sep 2011, 08:39 pm »
Did it ver work?  Can you return it to Ram for a chEck-up?
Ears
« Reply #3 on: 17 Sep 2011, 08:49 pm »
It was modded along with another  45 I owned around 5 years ago.  This is an easy fix for someone that knows what there doing , and it worked fine up until recently.
I already bought a Pioneer Elite sc 35 to replace it with.
It looks to be a stock Panasonic transistor that is making the high pitched clicking sound.. there for Ram has nothing to do with this receiver not working.
