Unified 1
0 Members and 1 Guest are viewing this topic. Read 1749 times.
Cortes
Unified 1
« on: 20 Aug 2011, 01:48 am »
Hi everyone,
  I'm researching for a small print monitor for my office (4X3 meters) to listen to moderated/low volume levels.
  It would go with a valve integrated Leben CS300X with just 15Wats. Some questions
  a) 15 Wats from a quality valve integrated is enough to driven with no much compromises the Unifield 1?
  b)  the Unfield 1 can be placed close to walls, or even between shelves?. How difficult are they to place?.
  Thanks.
JackD201
Re: Unified 1
« Reply #1 on: 22 Aug 2011, 07:35 am »
Hi Cortes, that Leben integrated is a sweet unit. I've heard them driving Harbeth compact 7s beautifully. I don't know how they'd sound with Unifield 1s though.
I have a pair of 300B Paralled monos that do a couple of watts more than the Lebens. I'll try them out with my Unifield 1s to see if there's enough juice and let you know in a few days. I'm not very optimistic though. I'm currently using 50wpc SS monos and they seem just right. I'm expecting that 15wpc might limit music to small ensemble affairs.
Oh, and yes the U1s can be put close to walls and still image well. They are front ported. If there's too much boundary reinforcement in the mid-bass region, all you have to do is stuff the ports with a bit of dacron.
« Last Edit: 22 Aug 2011, 11:33 am by JackD201 »
