0 Members and 1 Guest are viewing this topic. Read 4400 times.
Remove the gnome Ed.Problem solved...... Bob
Um, I think he needs to add the belt.... Just say'n....
Sorry for the OT Ed, I couldn't resist. Carry on gentlemen.Bob
What thickness is the absorption on the wall behind you?The hump is very very broad suggesting it's not necessarily a room issue unless you have a lot of smoothing turned on in your graph.Bryan
Nice, Ed, way to go! Your setup looks flat as a pancake in most regards! Would you mind posting a non-smoothed graph from 20-200Hz? That would give a little more resolution to the lower end. You may also want to take a look at your decay times....set that for 20-200Hz and 300ms. I also set the limits on my decay graphs following these steps (don't know if there is a better way but thought this seemed rational): first, I set the limits to 20-200Hz. Second, I set the SPL graph smoothing to 1/1 smoothing. This gives the closest to a flat line. I mark that with the mouse (let's say it's 85db). Third, I set the vertical limits to show 30db less than the 1/1 smoothing line (this would put the example at 85db -30db = 55db as the lower limit. Finally, I reset the upper limit to be higher than the highest peak by 10db (or whatever you like, maybe 30db above the average line would make sense too). Oh, and someone wise told me that flat is flat but what sounds good to you is what sounds good to you (and the two may be different). A little bass boost is nice if you can manage the decay times!Take care,John
The servo amp has a parametric eq in it, doesn't it? How is it set?
