Bugle starts distorting after 10 min use
0 Members and 1 Guest are viewing this topic. Read 1202 times.
amolsa
« on: 18 Aug 2011, 05:39 pm »
Hi
I just finished building the Bugle. The problem is that it starts distorting after some 10 min of use. This lead me to think it might be a problem with caps. I removed the 220uF elkos (at the + and -, I am using 14 V power supply) and the sound turned out to be similar to what I am hearing after 10 mins use now. Is it possible that the caps start leaking? I cannot see that they could have been destroyed. Should I consider changing to bigger caps?
jcg0322
Re: Bugle starts distorting after 10 min use
« Reply #1 on: 24 Aug 2011, 08:11 pm »
Amolsa,
I would gladly check your bugle out at no charge. Send it to me and you only pay shipping.
Jack
