Help needed with my new Denon 3803
0 Members and 1 Guest are viewing this topic. Read 1424 times.
AlaskaManSouth
« on: 16 Apr 2004, 09:42 pm »
I cannot figure out how to make the surround-back channel(s) function.  I've looked at the manual but I don't find any instructions.  Thanks for your help ...norm.
bob82274
« Reply #1 on: 16 Apr 2004, 10:29 pm »
I have the 3802 and for me it gives the option of using either those amps as either backs or as fronts for a second system.  Hit the menu button on the remote and look through the options that are displayed on your TV.  Another thing that I would suggest is that you use DTS-ES material as i'm not sure how its decoded when its just regular DTS or DD.
I don't know if this will help... if not I think that there are some guys here who do have that exact model.
AlaskaManSouth
« Reply #2 on: 17 Apr 2004, 11:54 pm »
I'm still unable to get the back-surround speakers to function.  Anybody out there with a Denon 3803 that can help?
rosconey
« Reply #3 on: 18 Apr 2004, 12:14 am »
