Album Art Challenges with MPaD
0 Members and 1 Guest are viewing this topic. Read 14276 times.
zybar
« on: 14 Aug 2011, 12:50 pm »
I am not seeing all of my album art even though "I think" that I have everything set up properly and each album has a jpg of the cover.
Here is what I have for settings in MPaD:
Local Cover Art Section:
URL -> bryston-bdp-1.local/music
Filename -> cover.jpg  (every album folder has a cover.jpg file)
Cover Art Section:
Fetch Local cover art -> On
Fetch from Amazon -> On
Fetch from Discogs -> On
A good part of my collection has the cover art embedded into each track.
What else do I need to do in order to see my album art.
Also, is there any way to increase the size of the cover art in MPAD?  The images are much smaller than what I am used to seeing SqueezeCenter or iPeng.
George
  • The Demo is Everything!
    • http://www.bryston.com
Re: Album Art Challenges with MPaD
« Reply #1 on: 14 Aug 2011, 02:10 pm »
Cover Art Section:
George
Hi George,
Yes this cover art thing seems very confusing at times as there seems to be so many ways of getting it. I know you have to be online in most cases with MPOD and MPAD.  I find sometimes I can see the album art in MAX and not in MPAD and visa -versa :scratch:
james
zybar
« Reply #2 on: 14 Aug 2011, 02:26 pm »
Hi George,
james
I am online at all times.  I don't think that is it.
George
zybar
« Reply #3 on: 14 Aug 2011, 03:01 pm »
James,
Looking at the MPaD website, I came across this thread:
http://www.katoemba.net/makesnosenseatall/2011/03/05/cover-art-in-mpod-and-mpad/
What about possibly incorporating some of the proposed solutions on the BDP-1 in the next firmware release?
George
« Reply #4 on: 14 Aug 2011, 03:22 pm »
James,
George
Sure sounds like a plan :thumb:
james
BrysTony
« Reply #5 on: 14 Aug 2011, 03:57 pm »
Cover Art Section:
George
George,
The URL should be:
http://bryston-bdp-1.local/music
If you do not have http:// in front of it, that may be the fix that you need.
Tony
zybar
« Reply #6 on: 14 Aug 2011, 04:08 pm »
George,
The URL should be:
Tony
Thanks Tony.
I will check that out right now.
George
OgOgilby
« Reply #7 on: 14 Aug 2011, 06:42 pm »
In the MPad "Edit Connection" section where you put the Local Cover Art URL (http://bryston-bdp-1.local/music) make sure the "Filename" area says "cover.jpg" if that is what you use. The filename is case sensitive.
If the album art file on your hard drive is named "cover.jpg", you should see it. If the album art file on your hard drive is named "Cover.jpg" or something else, it won't show up - unless you have "Fetch from Amazon -> On" or "Fetch from Discogs -> On". If you have "Fetch from Amazon" and "Fetch from Discogs" enabled, MPad will try to find the missing cover art on Amazon or Discogs.
-Greg
zybar
« Reply #8 on: 14 Aug 2011, 07:47 pm »
George,
The URL should be:
Tony
Tony,
That did the trick!   :thumb: :thumb:
Thanks again.
George
BrysTony
« Reply #9 on: 14 Aug 2011, 11:37 pm »
Tony,
Thanks again.
George
Enjoy!!   :thumb: :thumb:
Tony
ellsworth
« Reply #10 on: 23 Aug 2011, 08:12 pm »
FYI. Just posted this in the Mpad forum at http://www.katoemba.net/makesnosenseatall/mpad/comment-page-5/#comment-28027 :
Here’s an interesting (I think) anomaly I have come across while updating cover art in Mpad – if an album is listed twice under different Artists, the cover art will not update even when the correct jpg file is co-located with the audio tracks. A good example of this is the album “Be Yourself Tonight” by the Eurythmics. In scanning through my database listing by Artist name, this album shows up twice – once under Eurythmics, and once under Eurythmics/Elvis Costello. I could not get the cover art to update and display properly for this album even though it had the correct jpg file in place. Turns out that all the tracks on the album have Artist -> Eurythmics in their tag information except for the song Adrian which is Artist -> Eurythmics;Elvis Costello (ripped with dbPoweramp – don’t know why this didn’t happen for the tracks with Aretha Franklin or Stevie Wonder though?!?). Anyway, this causes Mpad to list the album twice under Artist, which also prevents it from updating and displaying the cover art correctly. While listing albums multiple times based on artist involvement is probably a good thing, not being able to display the cover art correctly is not. The workaround in this case was to edit the tag information for the song Adrian, change the artist to Eurythmics, update the database, refresh the local cache, and , voila, the cover art updates correctly right away. Further to this, before the correction, when viewing the available tracks with Mpad starting with the Artist, then the Album, and then the Tracks, all the tracks on this album displayed whether viewing them from Eurythmics or Eurythmics/Elvis Costello, even though there was only the one track that was Eurythmics/Elvis Costello. Any thoughts? Thanks.
Robin1
« Reply #11 on: 23 Aug 2011, 10:08 pm »
that's interesting. Iv'e been messing around for a few days now trying to figure out why I've got about 20 cd's out of 1200 that will not show covers. Everything looks the same from the ones that work to the ones that don't.......will have to go back in...check album names.
thanks for the tip
Robin
Robin1
« Reply #12 on: 29 Aug 2011, 01:39 am »
wow...I'm still struggling with this
under edit connection...I don't have a fetch local cover art...or fetch from amazon...or fetch from
discogs...just url and filename.  Where do I find cover art section
Robin
« Reply #13 on: 29 Aug 2011, 01:56 am »
Robin
Hi Robin
You may have to update to the newest version of mpod or mpad
James
catastrofe
  • "That's what credit cards are for. . ."
« Reply #14 on: 29 Aug 2011, 02:07 am »
Robin
Cover art is at the bottom of the main settings window.  Make sure your cover art is in the same folder as the album tracks.  Make sure the art file is either "cover.jpg" or "folder.jpg" and make sure the art filename in the settings matches your naming convention.  Make sure your URL is correct for the subfolder where your music files are stored.  For example, if they are in /music/FLAC, then the URL must match down to the FLAC level.
If this is all correct, select an album with missing art, and manually reaload using the button that displays.  Art from folders does not reload automatically.
Hope this helps. . .
ebag4
« Reply #15 on: 29 Aug 2011, 12:55 pm »
I am not running Bryston but I am running MPD and mPod, is there a way to determine if your music server is sharing you collection over http?  I am using a Netorked Media Tank as my server but do not know if something further is needed to serve up the cover art.
Ed
Robin1
« Reply #16 on: 1 Sep 2011, 06:10 pm »
thanks guys...downloaded the newest version of mpad...that fixed my cover art problem.
Did anybody notice on the new version the plus & arrow circle thingy is gone....hopefully not just on mine.
Robin
BrysTony
« Reply #17 on: 1 Sep 2011, 08:11 pm »
Robin
They changed it up a bit.  Go into settings and scroll down to play for the options.
Tony
Robin1
« Reply #18 on: 1 Sep 2011, 08:35 pm »
thanks Tony...I hadn't found that yet
Robin
WBimmer
« Reply #19 on: 9 Sep 2011, 11:21 pm »
I'm still having issues with mine not displaying all of them.
I have the latest version of MPaD and have the three settings turned on (local, amazon & discogs).
I'm thinking that the local is being missed and it's going straight to amazon becuase some covers are missing and some covers are not the ones I have loaded in the directory with the music.
My music is all ripped using DbPoweramp and it places the files into the album directory, under the artist directory.  The artist directory is the top layer of directory sitting on the drive.  The picture file is called Folder.jpg and I have MPaD looking to fetch the cover art from http://bryston-bdp-1.local/ and it isn't finding anything.
From what I can see, I'm doing everything right.  Any ideas?
Wayne.
