NEW BDP1 SOFTWARE
0 Members and 1 Guest are viewing this topic. Read 8336 times.
jjc1
NEW BDP1 SOFTWARE
« on: 12 Aug 2011, 03:30 pm »
James, I just installed the new BDP1 software. I recently saw on the sight where you mentioned what's new with this upgrade. Can't seem to find it. Can you plrease list them again?
  • The Demo is Everything!
    • http://www.bryston.com
Re: NEW BDP1 SOFTWARE
« Reply #1 on: 12 Aug 2011, 03:35 pm »
New Software July 2011
New software is available for the Bryston BDP-1 Digital Player.
The new software has the following added features:
•   Software rebuild using Debian Linux OS
•   New USB Mount Utility
•   Bryston Max and Mini interfaces have improved performance
•   Mini-2 is an added interface for use with iOS 4 devices (iPads,  iPhone, iTouch)  (can be used with Safari and Chrome on Laptop or Desktop)
•   Single finger scrolling on playlist with Bryston MAX
•   Boot-time is now 30 seconds shorter
•   MAC Formatted USB drives (HFS-Plus) can now be used
•   Read/Write to NTSF Drives as well as FAT32 Drives using SAMBA and read support for MAC HFS-Plus Drives
•   Updated Bryston Home and Settings page
•   Internet Radio – 16 preloaded stations
•   Scratch Drive utility (album art data base)
jjc1
« Reply #2 on: 12 Aug 2011, 06:47 pm »
Thanks James. But now when I try to use MAX it just continuously says loading and no playlist, USB or anything appear. The play, next etc. arrows are there but there is nothing to control. Unless I use another contoller like MPOD or Gnome.  Then the song playing is diplayed on MAX and I can STOP, go to NEXT but stil no Playlist or other functions! And it still says LOADING.
Anything you know that I should do?
« Reply #3 on: 12 Aug 2011, 06:49 pm »
I will discuss with my software guy - use MPOD for now.
james
SHV
« Reply #4 on: 12 Aug 2011, 06:53 pm »
"James, I just installed the new BDP1 software."
Where do I go to download the "new" software?  However after reading the last comment.....maybe I should wait.
« Reply #5 on: 12 Aug 2011, 07:04 pm »
Hi Steve - I have not had any issues other than above so you should be OK.
james
« Reply #6 on: 12 Aug 2011, 07:16 pm »
Hi - I assume you were using the BDP-1 before with no issues?
james
zybar
« Reply #7 on: 12 Aug 2011, 07:23 pm »
James,
Will my new unit have this firmware or will I need to upgrade?
George
« Reply #8 on: 12 Aug 2011, 07:24 pm »
James,
George
Hi George
We have been using the new software since mid July so you are set to go :thumb:
What did you think of the music attached?
james
jjc1
« Reply #9 on: 12 Aug 2011, 07:26 pm »
james
  Yes. No issues wit the BDP1 or with MAX. All other interfaces are still working fine and had no issues before upgrade either.
SHV
« Reply #10 on: 12 Aug 2011, 07:32 pm »
james
Where do I go to download the new software?
« Reply #11 on: 12 Aug 2011, 07:36 pm »
Email me at [email protected] - and let me know if you are using a PC (preferred) or MAC.  Also what version of software you have now - SO-98?
james
zybar
« Reply #12 on: 13 Aug 2011, 04:15 pm »
James,
My drive is NTFS, yet I still can't drag and drop.
Any ideas?
My firmware is the following:
S0-99
2011-04-01
George
« Reply #13 on: 13 Aug 2011, 04:24 pm »
Hi George - gee I am sorry I thought we installed July 15th software.
Send me an email at [email protected] and I will send you the update - are you using a PC?
james
zybar
« Reply #14 on: 13 Aug 2011, 04:30 pm »
james
Using a PC.
Will send e-mail right now.
George
werd
« Reply #15 on: 13 Aug 2011, 05:43 pm »
james
Can't we update right from the bdp?
zybar
« Reply #16 on: 13 Aug 2011, 05:49 pm »
Update is completed and I can now move files over the network.   :thumb:
George
« Reply #17 on: 13 Aug 2011, 06:31 pm »
Hi Lorne,
You update over the network using a file I send you.
james
werd
« Reply #18 on: 13 Aug 2011, 06:54 pm »
Hi Lorne,
james
Hi James
I guess that isn't the same as updating radio right?
« Reply #19 on: 13 Aug 2011, 07:01 pm »
Hi James
Correct we do that on the server at Bryston
James
