Preamp for LOMC cartridge
0 Members and 1 Guest are viewing this topic. Read 5607 times.
dkd7
« on: 12 Aug 2011, 10:05 am »
I have just acquired a SL1200 MK5 and was lookng at the Denon DL103R. My receiver isn't sensitive enough for the LOMC variants (Denon AVR-3300) so what would be a decent preamp or "booster" to use this cartridge?
Looking to stay under $300 but not set in stone.
jtsnead
Re: Preamp for LOMC cartridge
« Reply #1 on: 12 Aug 2011, 01:11 pm »
Look for a used Jasmine might be able to get one around $400 - $500
Just got a SL1210 myself.
Berndt
« Reply #2 on: 12 Aug 2011, 05:14 pm »
You might consider step up transformers.
DaveyW
« Reply #3 on: 12 Aug 2011, 06:11 pm »
Hi dkd - For that sort of money I'd recommend consideration of the Pro-ject SE II.
I compared a few mid spec Phono stages inc. the DV P75 and Trichord Dino, and preferred this.
Am running a Denon DL-S1 with it at the moment and remain very pleased.
Happy hunting,
Dave
« Reply #4 on: 12 Aug 2011, 07:22 pm »
There is a Vincent for sale right here on AC. I've never heard this unit but it falls in your price range
http://www.audiocircle.com/index.php?topic=96983.0
https://audioadvisor.com/prodinfo.asp?number=VIPHO8
sebrof
« Reply #5 on: 12 Aug 2011, 09:20 pm »
I recently bought a Musical Surroundings Phonomena Nova, used $600. The Nova is the battery powered version. The non-Nova does not have the batteries and usually sells for ~ $300 or so used I believe.
I use the Nova with a 103r and it works great. It has dip switches for Capacitance (secondary concern for MC carts), Resistance loading (very important, makes a huge difference with LOMCs) and gain up to 62 db which is what I have mine set to. I run a 4-watt SET amp so I don't have power to spare, and the 62 db is enough gain.
My understanding is that the Nova and non-Nova are very similar except for the batteries.
Made in California if that matters to you.
Hope this helps.
dkd7
« Reply #6 on: 13 Aug 2011, 12:24 am »
Another option is a HOMC cart but I feel if I were going to dive into this the 103 is the ticket.
I cannot answer any PM's yet as of my newbie status. I will check out the preamps that were listed....thanks.
« Reply #7 on: 14 Aug 2011, 11:52 pm »
PM sent
AudioSoul
« Reply #8 on: 15 Aug 2011, 01:55 am »
Does the AVR-3300 even have a phono section? I thought it was a home theater reciever...... 8)
dkd7
« Reply #9 on: 15 Aug 2011, 03:17 am »
Yes it does, however the sensitivity is 2.5mV. Here are the specs:
Input sensitivity:
2.5 mV
RIAA deviation:
±1 dB (20 Hz to 20 kHz)
Signal-to-noise ratio:
74 dB (A weighting, with 5 mV input)
Rated output / Maximum output:
150 mV / 8 V
Distortion factor:
0.03% (1 kHz, 3 V)
BaMorin
  • AR turntable rebuilder/modifyer
« Reply #10 on: 15 Aug 2011, 03:48 am »
DB Systems DB-8HG........less than the budget numbers you gave.........very impressive specs
dlaloum
« Reply #11 on: 15 Aug 2011, 04:24 am »
I'd take a look at the Firestone Audio Korora....
Battery powered, very flexible in terms of loading - and compares well to phono stages at substantially higher $...
It was on my short list....
Scottdazzle
« Reply #12 on: 15 Aug 2011, 01:57 pm »
You might find a used Jolida JD-9. There's often one on Audiogon.
dkd7
« Reply #13 on: 16 Aug 2011, 03:41 am »
So if I could make a list of what we have mentioned....how would a Yamaha CX-2 compare?
Not a complete list but all listed seem to be a serious consideration....just trying to eliminate any vintage possibilities....or not.
DB Systems DB-8HG
Jolida JD-9
Musical Surroundings Phonomena II
Vincent PHO-8
Cinemag 2330A is on my list also.
putz
« Reply #14 on: 16 Aug 2011, 04:04 am »
dkd7
« Reply #15 on: 16 Aug 2011, 11:10 am »
I believe I have the CX-2 confused with the C2-X.....the C2-X being the more desireable I assume?
BobM
« Reply #16 on: 16 Aug 2011, 05:50 pm »
Get a Hagerman Piccolo. Build it yourself and have some fun in the process.
dkd7
« Reply #17 on: 23 Aug 2011, 04:28 am »
Wanted to update to say I found a Yamaha CX-1000 for a great price and is in excellent condition.
I hooked it up tonight and was blown away. Absolutely night and day compared to the 3300...at least using a MC cart, but I think it will be that way across the board whichever cart I use.
