PCOCC Speaker Cables $40 - $70 - Sold
0 Members and 1 Guest are viewing this topic. Read 2100 times.
HT cOz
« on: 12 Aug 2011, 04:02 am »
Basic Info:
Price $55 Delivered
Left and Right cables are 7.25 feet long
16 gauge X4 per channel
CMC Banana Plugs
Wraped in mesh flex
These are speakers cables that I have made using 16 gauge PCOCC wire.  The left and right channel use 4 wires each and a set uses 60ft of wire in total.  They are terminated with CMC banana plugs and wraped in a flex mesh.  My goal with this project was to create a set of good looking/sounding wires that are relatively inexpensive but would not hold back a decent system.  As they are DIY they are not perfect, for example the 4 wire braid is not 100% perfect but very good.  It took me a lot of time to figure out all the steps involved but I am very happy with the final product.
The wire uses a hybrid geometry of 3 different size wires.  The 2 outer wires are wraped around the large center which is insulated from the other wires.
Here is a link to larger pictures https://picasaweb.google.com/111791796147706152881/PCOCCSpeakerWire#
Additional photos:
Thanks for looking,
Robert
« Last Edit: 18 Aug 2011, 08:18 pm by HT cOz »
wushuliu
Re: PCOCC Speaker Cables $125
« Reply #1 on: 12 Aug 2011, 06:11 am »
Good stuff. Very fair price, especially since it must have taken a bit of work to strip and do the geometry :wink:. Nice job!
HT cOz
« Reply #2 on: 12 Aug 2011, 01:50 pm »
Yes the process of striping the wire from the giant PVC jacket can only be described as painful.  The only reasonably priced source of PCOCC wire was from Belkin a few years ago.  The downside is that it is incased in a super PVC jacket that must be removed if you are to use the wire in multi-strand configurations.  I did not imagine the stripping would be so difficult  :duh: Next was trying to figure out how to use the multi-strands in a smart way which I eventually figured out.
My goal was to build a few cables to sell and cover the cost for my personal pair.  I will discount this first set to $105 as the braid is not perfect on my first attempt.
Robert
HT cOz
Re: PCOCC Speaker Cables $80
« Reply #3 on: 14 Aug 2011, 12:14 pm »
I changed the price to move this cable out.  :thumb:
HT cOz
Re: PCOCC Speaker Cables $55
« Reply #4 on: 16 Aug 2011, 06:20 pm »
This is my final price reduction and will gift them away if they don't sell.  This is a little less than cost for the parts.  Not to mention that PCOCC wire sells for between $1-$3 these days.  So if you want them jump now  :thumb:
HT cOz
« Reply #5 on: 18 Aug 2011, 05:17 am »
Here are a few more pictures from my leftover DIY project.
8ft perfect wind $70
Robert
« Last Edit: 22 Aug 2011, 07:32 pm by HT cOz »
