Potting the Felix
0 Members and 1 Guest are viewing this topic. Read 2201 times.
jtwrace
    • TIPP YouTube Channel
Potting the Felix
« on: 11 Aug 2011, 12:39 am »
I'm thinking about making a Felix using copper THHN wire.  Can I pot the Felix?  Is it safe?  If so, can anyone recommend a potting compound?
TIA
jtwrace
Re: Potting the Felix
« Reply #1 on: 12 Aug 2011, 01:25 am »
Anyone?
mgalusha
« Reply #2 on: 12 Aug 2011, 02:59 am »
Potting it should be fine. I use potting epoxy from AeroMarine Products
jtwrace
« Reply #3 on: 12 Aug 2011, 07:21 pm »
Thanks.  So does 2 qt kit make 1 gallon of compound?  Also, can you pour in stages?  Pour half then add a circuit and then add more compound on top of a fully cured previous pour?
mgalusha
« Reply #4 on: 12 Aug 2011, 07:34 pm »
No, 2qt's is the total amount. 1 quart resin, 1 quart hardener. With the potting compound you are not limited to thin layers, I pour about 1.5" deep in one shot. Not sure on doing multiple pours but it should be fine as with the other epoxies they sell there are explicit instructions to only pour layers with a maximum thickness of about 3/8". I checked with John Greer (the owner) and with the potting variety this is not a restriction.
jtwrace
« Reply #5 on: 12 Aug 2011, 07:37 pm »
Thanks.  What's the max thickness that I can pour with the 300/11?
jtwrace
« Reply #6 on: 13 Aug 2011, 12:00 am »
The answer from them is:
You can pour the 300/11 up to a 1/2 inch thickness at a time. You can build up the thickness through repeat pours. The product is guaranteed for a year but it lasts for quite a long time.
mgalusha
« Reply #7 on: 13 Aug 2011, 01:14 am »
Not the same answer they gave me. I've done over 150 boxes since I received this email and have not had any problems.
Good point- the exotherm of the potting epoxy is less so you should be able to pot 2".
John
On Tue, Feb 2, 2010 at 6:28 PM, Mike Galusha wrote:
    Hi John,
    I recently purchased some of your epoxy potting compound and the guideline sheet that was included said not to pour more than 3/8" deep. I was wondering if this applies to the potting mixture as well as the more general purposed epoxies. I ask because some of the potting boxes I'm using are 2" deep and filling them 3/8" at a time is obviously pretty slow. :)
jtwrace
« Reply #8 on: 13 Aug 2011, 01:18 am »
Interesting.  Maybe b/c you spoke with John and I spoke with Holly / Jennifer.   :dunno:  If you've done 2" deep with 300/11 then I should have no issues.
