Songbird / SongSub
0 Members and 1 Guest are viewing this topic. Read 2096 times.
Richard in Idaho
Songbird / SongSub
« on: 5 Aug 2011, 08:15 pm »
Some questions.
1. What are the dimensions of the SongSub?
2. using a pair of subs with a pair of Birds how much space would be needed for each set?
3. Where in relation to the towers should the sub be placed?
jonpol
Re: Songbird / SongSub
« Reply #1 on: 5 Aug 2011, 10:10 pm »
Some questions.
I measured mine a while ago in answer to someone else's question.  Here's a link to my response:
http://www.audiocircle.com/index.php?topic=94452.msg943135#msg943135
Hope that helps!
jsalk
« Reply #2 on: 8 Aug 2011, 04:54 pm »
Some questions.
The SongSub is 14" wide, 16" deep and 24" tall.
That all depends on where you place the subs.  Since you can adjust the phase of the subs, they can be placed almost anywhere (your sense of hearing cannot localize sources under about 150Hz or so).
Anywhere in the room that works is just fine.  Think more in terms of evenly pressurizing the room with the subs.  You can adjust the gain and phase of the subs to integrate them with the mains.
I hope this helps.
- Jim
charmerci
« Reply #3 on: 8 Aug 2011, 08:46 pm »
I personally find that placing the output of the sub directly in the middle between the two speakers (in a very large room) improves the soundstage.
