Can the 28BSST be too Powerful?
0 Members and 1 Guest are viewing this topic. Read 6794 times.
OwenMeany
« on: 5 Aug 2011, 04:05 pm »
I have, and very much enjoy, a pair of 28BSSTs. They are currently driving a pair if Verity Audio Parsifal Ovations and have been for the past couple of years. The VAPO are now on the market ($12.5k on Audiogon if anyone is interested), and the speaker I am looking at to replace them with have a 4 Ohm load...
Considering the 1kw+ of the Bryston's with a 8 Ohm load, could they be too powerful for the 4 Ohm load? I am primarily concerned about damaging the speakers or amp...
Thanks for any input....jtb
  • The Demo is Everything!
    • http://www.bryston.com
Re: Can the 28BSST be too Powerful?
« Reply #1 on: 5 Aug 2011, 04:07 pm »
Hi,
Not to worry - you can do much more damage under powering a speaker (clipping the waveform).
james
werd
« Reply #2 on: 5 Aug 2011, 04:41 pm »
Not an issue. I have my 14B at 650 watts driving my 150 watt AZ's. Just listen for clipping and keep it below that volume.
Laundrew
« Reply #3 on: 5 Aug 2011, 04:53 pm »
Hi,
james
So very true - I had an old Sony receiver that was famous for eating speakers. I guess that square waves and speakers are not compatible.  :lol:
Be well...
1oldguy
« Reply #4 on: 5 Aug 2011, 04:55 pm »
Too Powerful...I like the sound of that. :wink:
vegasdave
« Reply #5 on: 5 Aug 2011, 10:33 pm »
For that 4 ohm load, the 28Bs are more than fine.
WBimmer
« Reply #6 on: 5 Aug 2011, 11:40 pm »
You can never have too much power...
My Proac's are 4 ohm speakers and they sound fantastic on the 28B-SST2 amps that I have.
My dealer reckons these amps are capable of 2400 wpc into a 4 ohm load, so that sounds just about right for my liking.   :D
95Dyna
« Reply #7 on: 6 Aug 2011, 02:59 am »
They measure in at over 1800 wpc @ 4 ohms according to John Atkinson of Stereophile.
vegasdave
« Reply #8 on: 6 Aug 2011, 09:31 pm »
Nice! What a superb amplifier! :D
1oldguy
« Reply #9 on: 6 Aug 2011, 10:17 pm »
Curious.....Maybe someone knows what changes there have been in the 28B from when it was first introduced and now with today's version?
« Last Edit: 8 Aug 2011, 12:01 pm by 1oldguy »
vegasdave
« Reply #10 on: 6 Aug 2011, 10:46 pm »
James would.
1oldguy
« Reply #11 on: 8 Aug 2011, 12:02 pm »
Hi James...
I would think you would know the answer,curious to learn all I can about the Silverado's. :thumb:
« Reply #12 on: 8 Aug 2011, 12:08 pm »
Hi James...
Changes have been the transformers used and the capacitors in the main circuit boards and input stage.
James
1oldguy
« Reply #13 on: 8 Aug 2011, 12:16 pm »
Thanks James
Just a couple more questions?
Is there a review out there that has been done since it was updated?
Do you remember the date they were first introduced?
Brandon
« Reply #14 on: 8 Aug 2011, 12:19 pm »
Thanks James
Brandon
The Absolute Sound Magazine has been commenting on the upgrades as they have evolved - Harry Pearsons reviews
James
SoundGame
« Reply #15 on: 8 Aug 2011, 12:25 pm »
I believe it was launched sometime in the later summer / early fall of 2006.
1oldguy
« Reply #16 on: 8 Aug 2011, 02:19 pm »
Would anyone have a link to said review after they were injected with the extra testosterone? ?
SoundGame
« Reply #17 on: 8 Aug 2011, 02:21 pm »
bryston.com/pdfs/08/Absolute%20Sound%2028B%20SST.pdf
1oldguy
« Reply #18 on: 8 Aug 2011, 02:33 pm »
Hi James
Wondering if the new transformer and caps were in the 28's at the time of this review?
I get the impression that the amps were new to the reviewer at the time,correct me if I'm wrong.
« Reply #19 on: 8 Aug 2011, 02:45 pm »
Hi James
You are correct - Harry reviewed the newer versions later and gave us a Product of The Year Award.
james
