Highest quality transformer manufacturer?
0 Members and 1 Guest are viewing this topic. Read 2803 times.
skibum
« on: 4 Aug 2011, 01:02 pm »
Hello,
I am looking for a couple transformers to use in a DAC.  Need one for digital stages and one for analog.  I am pretty sure I am looking for a toroidal design with separate screens for the primary and secondary sides.
Who makes the best quality out there?
I am located in Europe so really would prefer a European supplier.
Regards
Skibum
geowak
Re: Highest quality transformer manufacturer?
« Reply #1 on: 4 Aug 2011, 04:52 pm »
I am very interested in this question too. I know that many quality manufacturers use this company.
http://www.plitron.com/
(IE McCormack, Bryston, Counterpoint)
But I also know there are other top notch companies out there. The additional related question would be this-
Which manufacturers use the best transformers as STOCK in thier products?
roscoeiii
« Reply #2 on: 4 Aug 2011, 05:10 pm »
I saw somewhere recently that the best type of transformer will depend on its application. Think it was the Schiit DAC thread on HeadFi...
skibum
« Reply #3 on: 4 Aug 2011, 05:28 pm »
I agree.  But my question is which manufacturer makes the best quality transformers.
I like Plitron and if I lived in he USA or Canada I think that is who I would go with.  But with shipping, VAT, etc.  - Kind of a hassle.
bacobits1
« Reply #4 on: 4 Aug 2011, 05:31 pm »
Since you are in Europe why not check out Trafomatic.
Supposed to make some pretty good transformers.
I'm sure Boris from Vista Engineering can also answer some questions.
http://www.engineeringvista.com/
http://www.trafomatic.com/eng_home.htm
skibum
« Reply #5 on: 4 Aug 2011, 06:54 pm »
Great thanks for that, I had not heard about trafomatic
Quiet Earth
« Reply #6 on: 6 Aug 2011, 07:09 pm »
Some would say that Audio Note U.K. make the best quality transformers, while others might get upset if someone says that  :wink:. I guess you will have to decide for yourself. Audio Note makes transformers for the digital output of the transport, the digital input receiver of the DAC, the interstage I/V conversion,  and the analog output (step down). There are other transformers as well.
You can buy some of them here http://www.hificollective.co.uk/catalog/default.php?cPath=61_78 , or from this list : http://www.audionote.co.uk/comp/kit_sellers.shtml. I don't know if you can buy their very best parts without buying them in their finished products though.
Good luck  :thumb:
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #7 on: 13 Sep 2011, 09:17 pm »
parts connexion carries the audionote transformers
