Matrix Quattro Amp and DAC
0 Members and 1 Guest are viewing this topic. Read 5144 times.
guido
« on: 3 Aug 2011, 03:21 pm »
Does anyone here use the Matrix Quattro Amp and DAC?
I am using the DAC at the moment with its onboard headphone amp and am suitably impressed.
I am waiting for the Quattro amp to arrive to use in balanced mode with the DAC and a balanced cable for my HD800s.
Links here:
http://www.matrix-digi.com/english/cpshow.asp?pid=24
http://www.matrix-digi.com/english/cpshow.asp?pid=25
Quattro Dac:
MATRIX MATRIX QUATTRO audio system is designed to develop a set of desktop, high-quality audio playback system.
QUATTRO audio system includes a QUATTRO DAC and a QUATTRO AMP, the appearance of two hosts with the same design elements with the same external dimensions, which can also be used independently.
QUATTRO DAC is a combination of high-speed digital signal processing technology, multi-D / A converters, with a variety of input and output ports can be used with a variety of devices.
QUATTRO audio system through careful circuit design, high quality devices use, professional-grade playback, the traditional audio equipment to a new height.
MATRIX QUATTRO DAC with top AD1853 24Bit/192kHz D / A conversion unit, fully balanced architecture. Oversampling unit within the ASRC, with MATRIX CPLD unique algorithm can effectively reduce the input signal jitter, four high-speed signal PCB layout, sophisticated design QUATTRO DAC has the following features:
• Low Jitter rate with a professional digital receiver chip and independent clock.
• has a fiber optic, coaxial, USB, AES / EBU and analog inputs and a variety of input methods, and automatic detection of input.
• USB supports up to 24BIT/96kHz sample input, other input port supports up to 24BIT/192kHz sampling.
• Automatic de-emphasis, can be automatically 32,44.1,48,96 K sampling rate signal for automatic de-emphasis control.
• Internal high-speed CLPD XILINX MATRIX has its own algorithm, sampling rate boost circuit with ASRC reduce jitter.
• analog with balanced and unbalanced outputs can be connected to different interfaces.
• High-quality LME49600 headphone amplifier unit can easily drive up to 600 Euro impedance headphones.
• digital input port with ESD static protection and transformer isolation protection.
• Analog output with low distortion audio-specific op-amp LM4562, to get the best signal playback.
• High-quality audio NORATEL dedicated toroidal transformer, the circuit unit with an independent multi-level power supply.
• High-quality NEUTRIK audio connectors.
• High-quality ALPS volume potentiometer.
• Multi-voltage compatible design.
• with infrared remote control.
• natural sound performance with texture, ultra-high resolving power and signal to noise ratio for you to discover the music every minute detail. Fully meet your high-quality Hi-Fi audio needs.
● Specifications
Input port:
Optical interface: shielded optical digital input
Sampling rate support 24Bit 32kHz-192kHz
BNC coaxial connector: BNC 75 ohm impedance sampling rate support 24Bit 32kHz-192kHz
USB interface: USB-B interface, the sampling rate support 24Bit 44.1kHz-96kHz
AES / EBU: XLR 110 ohms impedance sampling rate support 24Bit 32kHz-192kHz
Analog Input: RCA terminal 20Hz-20kHz 47kOhms Lotus
Output port:
RCA connector Output level: 0V-2.0V adjustable
XLR connectors output level: 0V-4.0V adjustable (XLR interface definition: 1 = ground, 2 = hot, 3 = cold)
Frequency response: 20Hz-20KHz
Signal to noise ratio: 114dB
Dynamic Range: 110dB
Distortion: <0.00056% (1kHz)
Headphone Amplifier:
Output impedance: <0.11 Ohms
Maximum output current: 300mA
Gain Bandwidth:> 500kHz
Signal to noise ratio: 106dB
Distortion: <0.0005%
Power requirements:
Power: AC 220V-240V 50/60Hz (AC 110V-120V 50/60Hz)
Working power consumption: <25W
Standby power consumption: <2W
Other specifications:
Operating temperature: 0 - +40 ℃
Weight: 1.6kg
Size: 205 × 245 × 44 (L × W × H)
Fuse size: 5 × 20mm 250V 0.5A
Quattro Amp:
QUATTRO AMP is a fully independent four-channel amplifier with balanced / unbalanced headphone amplifier, headphones with MATRIX-specific detection, designed to balance the drive design, the headset is also compatible with non-equilibrium.
MATRIX QUATTRO AMP within the independent four-channel high-quality broadband amplifier, fully balanced architecture.MATRIX unique headset with auto-detection function, professional analog audio signal PCB layout, sophisticated design QUATTRO AMP has the following features:
• have a balanced and unbalanced analog inputs can be connected to different interfaces of analog audio equipment.
• The headset can automatically detect the connection type, automatic conversion output.
• Driving the two pairs of non-headphone or a balanced approach to the way Fu Pingheng headphones.
• ultra-low distortion audio-specific op-amp to get the best signal playback.
• Infrared remote control with function.
• natural sound performance with a texture, a strong driving force to drive any size of moving coil headphones, to fully meet your high-quality Hi-Fi headphone amplifier.
● Specifications
Analog Input:
XLR connectors
Frequency response: 10Hz (-0.3dB) to 35 kHz (-1dB)
SNR:> 98dB at 0dB gain
Distortion: <0.001% at 6mW/300 Ohms
RCA connectors
Input impedance: 47Kohms
SNR:> 95dB at 0dB gain
Headphone Output:
Balanced approach
Maximum output current: 1000mA
Output power: 400mW/300 Ohms, 800mW/60 Ohms
Non-equilibrium approach
Maximum Output Current: 500mA
Output power 200mW/300 Ohms, 400mW/60 Ohms
Power requirements:
Weight: 1.6kg
wilsynet
Re: Matrix Quattro Amp and DAC
« Reply #1 on: 4 Aug 2011, 06:13 am »
Sounds like an advertisement.
toddbagwell
« Reply #2 on: 4 Aug 2011, 07:05 am »
I thought so as well. The OP posted about other things that didn't seem as "advertise-y" in other circles.
I thought I'd let it ride.
Todd
eclein
« Reply #3 on: 4 Aug 2011, 07:14 am »
I would use that post as a prime example of what an advertisement looks like. LOL....if thats not an ad I'd honestly be shocked.
Just my honest appraisal of the post.... 8)
guido
« Reply #4 on: 4 Aug 2011, 09:22 am »
I have no affiliation with Matrix...I live in South Africa and ordered one off eBay..
I just thought I would share my opinions on an interesting new product... :duh:
toddbagwell
« Reply #5 on: 4 Aug 2011, 11:44 am »
No worries, from your standpoint, i'm sure you figured you'd save us the trouble of clicking through the links and just post the pics and specs into your message.
And from some of our (perhaps cynical or "experienced") viewpoints, your post lacked a bit of the usual excitement of a new poster with new gear.
Anyway, welcome, and keep us up to speed as to how you are liking your setup.
Todd
eclein
« Reply #6 on: 4 Aug 2011, 12:53 pm »
guido- Its all Good, my remarks were not meant to incite and were made with tongue in cheek....I apologize to all if I was out of line.
 The headphone amp is pretty good huh?? I'm always looking for neat headphone amps, I didn't look yet at the price but is it worth the dollar amount, is it a huge bang for the buck???
guido
« Reply #7 on: 4 Aug 2011, 12:57 pm »
No problem guys...it was just a heads-up on what I perceive to be a very good product for the money.
It seems to be designed around the Benchmark DAC1 HDR\pre philosophy with a few tweaks and changes...and costs 1\3 of the price....lots of discussion on other hi-fi forums about the similarities.
I am now waiting for the matching balanced amp to arrive to bring out the full potential on my HD800s with a balanced cable.
eclein
« Reply #8 on: 4 Aug 2011, 12:58 pm »
I couldn't find the US dollar amount anywhere....how much are these babies??
guido
« Reply #9 on: 4 Aug 2011, 01:00 pm »
eclein
« Reply #10 on: 4 Aug 2011, 01:06 pm »
Thanks!!!!  :thumb:
