Connecting a 370bx-transformer (Cornet)
0 Members and 1 Guest are viewing this topic. Read 1625 times.
renton1
« on: 15 Apr 2004, 08:38 am »
Hi,
I´m an absolute beginner in tube-amps and have bulit a cornet as my first one. The only thing left is connecting the transformer. I don´t understand the schematics on it. Can anyone please tell how it should be connected to run the preamp at 220 to 240 Volts?
Many thanks and best wishes,
Ralf
mgalusha
« Reply #1 on: 15 Apr 2004, 02:10 pm »
Ralf,
According to the Hammond web site the connections are as follows:
220V primary
Line -> Blue/Yellow
Neutral -> White
Connect the Brown to the Black/Red.
All other leads are unused and should be insulated.
240V primary
Line -> Blue
Neutral -> White
Connect the Brown to the Black.
The diagram is located at: http://www.hammondmfg.com/300series.htm - scroll to nearly the bottom of the page.
Hope this helps.
mike g.
library
210 or 230V possible also.
« Reply #2 on: 15 Apr 2004, 04:03 pm »
Try to look at the schematics at hammond home page. I am running my nval cornet at 210V.
