Dared SL-2000A preamp experience/opinions...?
0 Members and 1 Guest are viewing this topic. Read 15355 times.
bladesmith
  • water quenching steel since 2001....
    • palmer knives
« on: 30 Jul 2011, 07:41 pm »
I have been looking at this Dared tube preamp ( SL-2000A)
Anyone have any experience or heard anything good or bad about this little tube preamp....?
It's looks like it might be alright to hook up to a SS amp and get some descent sound...(?)
thanks....
Meicheng
Re: Dared SL-2000A preamp experience/opinions...?
« Reply #1 on: 30 Jul 2011, 08:06 pm »
I had one of these and didn't really like it.  Lots of tube rush, a little bit of background hiss/noise and really cheap feeling remote.  In this price range I would look for a used Audio Experience Symphonies Plus preamp, which IMO is much better.
dangerbird
« Reply #2 on: 30 Jul 2011, 09:29 pm »
Mine is dead quiet,,it responds very well to tube rolling,,I upgraded the caps in mine--but,stock with the right tubes,I think it's a great bang/buck, just my .02 worth.
cjmustang69
« Reply #3 on: 31 Jul 2011, 01:05 am »
I have a Dared SL2000A preamp - bought it several months ago as my first step into "tubes.  I read a lot of good reviews about it - particularly on Polk Forum from members whose opinions I respect highly.  I'm very satisfied with its performance - particularly after changing out the stock tubes.  The preamp is dead silent and I'm running it with an Onkyo M504 amp in my second system.  In my opinion, it performs well above its price point.
dangerbird
« Reply #4 on: 31 Jul 2011, 03:17 am »
I got mine from a PF member,, try some Syl 5965's,,you'll love em' inexpensive too.
bladesmith
    • palmer knives
« Reply #5 on: 12 Aug 2011, 09:51 pm »
Just ordered a new Dared s-2000a preamp, should get it next week.
Going to put it front of a SS amp and see how it sounds on my second system..
Anyone experimenting with different tubes in their Dared preamp...?
-bladesmith..
Poultrygeist
« Reply #6 on: 12 Aug 2011, 10:14 pm »
I have the Dared 2a3c which after exchanging the terrible Chinese 6n3 signal tubes for WE 396A's is an excellent amp. Dared's products are high quality.
50jess
« Reply #7 on: 4 Sep 2011, 09:29 am »
Quite impressive even with the stock tubes and capacitors.  I use it as a pre-amp to a Virtue 2.2.  Changing to NOS tubes and probably upgrade the caps.
Chris Adams
« Reply #8 on: 4 Sep 2011, 01:06 pm »
I purchased a new SL-2000A about six weeks ago and it is fantastic. I wanted to try a tube pre in front of my SS amps. Worked so well that I upgraded almost immediately. I spent twice the money and got a little bit of improvement. For the money and even for quite a bit more, I think the Dared is a giant killer.
50jess
« Reply #9 on: 7 Sep 2011, 12:48 pm »
What SS amp are you using, Chris?
Chris Adams
« Reply #10 on: 7 Sep 2011, 01:18 pm »
I have a few, but for now I built a Hifimediy T3 mono block pair. 300w into 4ohms of very nice Tripath power. Also a pair of Tube Audio Design Hibachi mono amps. Both of these worked very nicely with the Dared.
50jess
« Reply #11 on: 7 Sep 2011, 02:48 pm »
With what speakers?
Chris Adams
« Reply #12 on: 7 Sep 2011, 03:32 pm »
Modded Magnepan MMGs.
Tubeburner
« Reply #13 on: 7 Sep 2011, 05:20 pm »
The little Dared smoked a Cary SLP 98 preamp. Change the rectifier to a Sylvania 5Y3 and use either RCA 5963 black plate or Seimen E81CC. Excellant for the money IMO.
50jess
« Reply #14 on: 8 Sep 2011, 12:06 am »
Is your Dared of the earlier version with Auricaps?
Tubeburner
« Reply #15 on: 8 Sep 2011, 01:09 am »
When I owned the  Dared, it had the Auricaps and the gold contacts. The remote was a small wood piece. I believe this was the second version...? My next preamp cost $2700 and had a wider sound stage, but this is a matter of taste, like many decisions in audio, not a better value. The Dared is a very good piece, IMO.
50jess
« Reply #16 on: 9 Sep 2011, 10:39 pm »
Is the 5Y3 rectifier as important as the 12AT7 tubes in influencing the sonic character of this preamp?
Tubeburner
« Reply #17 on: 9 Sep 2011, 11:13 pm »
Yes, the rectifier makes a big difference. I did not like the Mullard GZ34/5AR4 in this preamp, but the relatively cheap Sylvania was quite nice.
