BDA-1 fails to play 192KHz 24bit audio files, help please...
0 Members and 1 Guest are viewing this topic. Read 3243 times.
qscott
Hello Everyone,
I've searched through this forum and the internet and couldn't find anything that could help me sort out my play back problems with high-res audio files 192KHz 24bit via the BDA-1.
I'm playing the files on my HTPC via optical cable to my BDA-1 with no sound for the 192KHz files. Other sample rate files work fine it's just the 192KHz files that fail.
When I play different sample rate files the Sample Rate LED Array changes so I know different sample rates are being received correctly and played on the BDA-1.
Playing the 192KHz files the input LED turns RED on the BDA-1 and no sound is heard. I've also tried my laptop as well via a SPDIF inputs using a coaxial cable with exactly the same results.
Could there be an issue with the BDA-1 or just my setup?
Any help or advice would be greatly appreciated.
Thanks in advance,
Q
Setup
Mother Board = ASUS P7H55D-M EVO - http://www.asus.com.au/Motherboards/Intel_Socket_1156/P7H55DM_EVO/
Driver = ASIO4ALL 2.10 - English - http://www.asio4all.com/ (after doing some research I understand this gives me bit prefect output from my HTPC thru to the BDA-1)
Player = foobar2000 and xbmc (same results on both players using the ASIO driver)
Output
Optical via in to the TOSLINK input on the BDA-1
What works
Sample rates: 32KHz, 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, • 16-24Bit PCM
What doesn't
Sample rates: 192KHz • 16-24Bit PCM
Test Audio File Used
Format                           : FLAC
Format/Info                      : Free Lossless Audio Codec
Duration                         : 9mn 14s
Bit rate mode                    : Variable
Bit rate                         : 5 111 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 192 KHz
Bit depth                        : 24 bits
Stream size                      : 338 MiB (100%)
Writing library                  : libFLAC 1.2.1 (UTC 2007-09-17)
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-1 fails to play 192KHz 24bit audio files, help please...
« Reply #1 on: 30 Jul 2011, 11:01 am »
Hello Everyone,
Thanks in advance,
Q
Setup
Output
What works
What doesn't
Format                           : FLAC
Duration                         : 9mn 14s
Bit depth                        : 24 bits
Hi qscott
I can say without doubt it is NOT the BDA-1.  The RED LED means it is not receiving the 192/24 signal from the source.  The Toshlink or the motherboard or the setup may be the problem - is there a COAX out available to try?
I usually get about a call every 2 weeks or so from customers that have similar issues with high resolution files. That's one of the reasons I developed the BDP-1 Digital Player - been there - done that :duh:
The great thing about the BDA-1 is it tells you what is coming IN whereas a lot of DAC's tell you what is going OUT so you do not know if the DAC or Laptop or Computer is doing any upsampling etc.  Sadly there are a lot of people out there that think they are listening to NATIVE HIGH RESOLUTION digital music and they are NOT :duh:
james
« Last Edit: 30 Jul 2011, 02:24 pm by James Tanner »
Phil A
« Reply #2 on: 30 Jul 2011, 01:55 pm »
Definitely not the BDA-1 as James noted.  I use mine with an HDMI audio de-embedder and have played with various universal transports to take hi-rez PCM from SACD and pass DVD-A into the DAC.  I've gotten the red light on a couple and I've also gotten the sampling frequency to lock with no sound as the particular transport I was using needed an HDMI handshake.
HAL
« Reply #3 on: 30 Jul 2011, 02:17 pm »
Looking at the MB specs it does not say it supports 24bit/192KHz via optical.  Most optical outs are limited to 24Hz/96KHz.  You might check with ASUS to see.
Phil A
« Reply #4 on: 30 Jul 2011, 02:28 pm »
I've personally not tried it but the manual would imply, except for the USB, 24/192 is supported by the other inputs - http://www.bryston.com/pdfs/09/BDA1_MANUAL_20090710(4pg).pdf
I use the four coax inputs
srb
« Reply #5 on: 30 Jul 2011, 04:03 pm »
While it's possible that some TOSLINK outputs may not support 24/192 or that a marginal optical cable might be problematic, qscott did say he tried it on another computer with the same results (though I'm not sure what kind of laptop has an S/PDIF coaxial output).  And it works with 24/176.4.
qscott, you mention the "test file" used, have you also tried it with other 24/192 files?
qscott
Hi Guy's,
Thanks for the feedback.
I have tried a number of other test files 96KHz and 192KHz via the optical TOSLINK input (HTPC) and the S/PDIF coaxial input (Laptop using a docking station) on the DBA-1 with same results. I'll go back and test for the 176.4KHz sample rate and as it was only a once off test I ran for that, pretty sure it worked OK. Let you know.
I do have other optical cables so I'll try that as well. I just hope something will fix it or I'll have to take up James's solution and pick up a BDP-1  :P
HAL ASUS do quote that the optical does output 24bit/192KHz via optical, I'm starting to wonder just how true that is.
Also I've used/tested the WASAPI driver and have come up with the same results - http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Components_0.9/WASAPI_output_support_(foo_out_wasapi)
Will be in touch.
Q
Mag
« Reply #7 on: 20 Jun 2013, 03:33 am »
What gives, I'm having similar results? :?
TV display shows LPCM 2.0 96 khz/24 bit 4.6 Mbps. But BDA-1 only lights up 48K?
I have an HDMI cable going to HDTV and coaxial to BDA-1, downmixed to pcm stereo.
